Forged Internals vs. New Short Block
Old Oct 26, 2017 | 03:25 AM
GHO5T's Avatar
Default Forged Internals vs. New Short Block
Cost-wise, what would be the most budget friendly option? Buying a forged rotating assembly and use your existing LS block OR buying a new block with a forged rotating assembly from a vendor? If I were to guess, the expense of machining your existing block would jack up the costs close to buying a brand new short block.
What if you decided to use the stock GM crankshaft? Would it then be cheaper to use your existing block?
Old Oct 26, 2017 | 05:56 AM
HCI2000SS's Avatar
In my case it was a better deal to sell my aluminum LS1 block and buy a forged iron LQ9 block from TMS. I used my existing top end and it came with a stock GM crankshaft
Old Oct 26, 2017 | 07:16 AM
GHO5T's Avatar
Nice! How many miles on the stock short block and how much did you get for it?
I’m sure machining costs differ depending on your location.
Old Oct 26, 2017 | 07:30 AM
HCI2000SS's Avatar
The motor had around 80k when it blew. I don't remember exactly, but I wanna say I got around $400 for the block. Took that money and put it towards a fully balance and blueprinted LQ9
Old Oct 26, 2017 | 09:17 AM
KCS's Avatar
KCS
Moderator
That's really a loaded question because of all the variables. Prices vary by shop and what components you're talking about using. Usually new blocks still need machine work, as most pistons are going to be for an oversized bore. The majority of factory blocks are not torque plate honed, so most machinists will insist on using an oversized piston to hone the cylinder straighter and rounder than they came from GM. Plus you're probably going to pay more for a new block than for an older used block, but you do run the risk of getting screwed with a used block if it's damaged beyond repair.
Old Oct 27, 2017 | 08:30 AM
GHO5T's Avatar
So as an example let’s use a 50k mile stock ls6 short block. Block is fine, machining costs, assembly, new bearings, new bolts, stock GM crank, forged rods and pistons/rings. (Let’s assume average machining costs)
How would that compare to a new ready-to-order and assembled GM ls2 aluminum block, GM crank, same forged rods, pistons and hardware?
Old Oct 27, 2017 | 09:20 AM
KCS's Avatar
KCS
Moderator
It's going to be more expensive to buy the assembled shortblock. Mainly because the LS2 block is more valuable than the LS6 and because you're probably going to have to pay for shipping the shortblock.
The machine shop local to me will do a stock rebuild with your LS for about $900. You get it disassembled, cleaned, and rebuilt with new rings, bearings, and basic machining. Forged rods and pistons will add about $1100, plus about $250 to balance the crank for the new rods and pistons. Let's call it $2250.
Now try to find a forged rod and piston LS2 for less than $4000.
Old Jul 24, 2018 | 08:15 PM
Jason Lester's Avatar
What machine shop is this? What power level would a block they build be good for? Just asking because I'm in the market for a forged block.
Old Jul 25, 2018 | 07:00 AM
KCS's Avatar
KCS
Moderator
Thats pretty much the going rate for the Houston machine shops, but it’s the bare bones work needed to get an engine together. As more power is expected, more work will be needed, like cutting the deck of the block for the right surface finish or line honing the mains for ARP studs, the price goes up.
Old Jul 25, 2018 | 07:16 AM
Gotcha. Would you care to throw in a recommended shop for an 800hp LS3 build? We are in the same area.
Thanks
Old Jul 25, 2018 | 07:49 AM
Mavn's Avatar
"I MAID THEESE"
Thanks
Bone stock ls3 with boost will hold 800 all day.
Old Jul 25, 2018 | 07:53 AM
For how long? How much more could I throw at it? Mine is running 775 and I want to keep pushing.
Old Jul 25, 2018 | 08:09 AM
KCS's Avatar
KCS
Moderator
Thanks
I like Nickens Bros in Conroe. Late Model Engines is also in Houston off Brittmore and they definitely know their way around high horsepower LS engines. Above all, I would take the drive up to Dallas and see Erik at Horsepower Research.
Old Jul 25, 2018 | 08:18 AM
codyvette's Avatar
It's definitely cheaper to have the machine work done and assemble yourself. It may not be best, but definitely cheaper. If you are not close to a machine shop that could change due to shipping two ways.
Old Jul 25, 2018 | 08:28 AM
Mavn's Avatar
"I MAID THEESE"
Depends on the boost level, Tune, etc...
Old Jul 25, 2018 | 09:02 AM
14 PSI right now running E85. Was going to run a smaller pulley and NW102 TB, probably put me over 800 for sure...Considering a 100 shot, but not sure about that yet.
Old Jul 25, 2018 | 10:50 AM
thompson's Avatar
If you are still looking to get either a rotating assembly or a short block built, you are more than welcome to give us a shout, We will be more than happy to grab you some pricing and let you know the best route to take at that point.
Thank you
Dustin
TMS
972-853-2450
dustin@thompsonmotorsports.net
Old Jul 25, 2018 | 10:57 AM
OP hasn't been here since October of last year.
Old Jul 25, 2018 | 01:28 PM
Ls7colorado's Avatar
Still good advertising none the less.
Old Jul 26, 2018 | 11:45 AM
Thanks for the recommendations. I spoke with Wayne at Nickens Bros, I may have them do it.
