Cam advice
Cam and springs run $515 shipped for the set. Uses your pushrods also. We can at least match but likely beat your power goals as well.
Email me for more info
Rpmspeedtech@gmail.com
If you want a decent gain in power and don't want more chop etc, I'd recommend doing heads instead.
I'm sure tech@ws6store can get you a great cam to meet your goals, but if you want decent gains without going to a decent size cam, I think heads would be a great route to go. Intake would be nice, but the gains for the $$$ is semi low in comparison to other mods. But at some point that intake will be a restriction. But not yet IMO
I'd also recommend replacing those trunions with bushing trunions, lot's of reports of wear issues with the roller trunions (non OE ones)
lingenfelter gt2-3 207/220 .571/.578 118.5 lsa
Comp xfi265hr high lift 212/218 .558/.563 115 lsa
both of these cams will idle and drive really nice and have gentle lobes that will still work great with your ls6 springs even with their added lift over your current cam.
I run the comp cam I suggested with ls6 springs in my daily driver and the valvetrain is just as quiet as it was when it was stock.
I believe either of these cams would ET just as well or better than your current one given the rest of your setup. Plenty of LS1's have ridden both of these grinds into the 11's over the years without too much drama.
From what I see the Howards hot cam is .525/.525 219/228 112
They have more lift but less duration. Seems that it'll mostly be a wash power wise (actually I bet the howards makes a little more) yet harder on valve springs.
He also stated he wants the same power or MORE and less aggressive lobes and less valve train noise. The cams mentioned would work for that, but I was also shooting for the same or more power part of his post, and the easier on the valve train part. The more power part was my personal preference lol
he said his setup makes peak power at 5900rpm. These cams are known to peak a little higher than that. If he can shift his 4:10 gears a few rpm higher he could be a little quicker at the strip.
We can get him a very nice lobe with our high lift hot cam lobes cut on a 115 and it will have exactly what he wants. They are super quiet and (from what i can tell) less aggressive than the howards lobes. Every customer comments on how quiet they are vs other cams no matter what springs and rockers they are running. All he needs to change are valve springs and cam. AND right now that cam kit would be on sale for $489 shipped.
Plus it would be a GREAT incidental comparison also.
I seriously doubt a custom grind a few degrees more would really make that big of a difference.
Its a trade off and a measure of how good your cyl heads are. On better cyl heads youd see the gains difinitively from less overlap but more lsa.
The 116 C/L will remove the "chop" and GAIN 2 HP at 6000 RPM, the Torque will DROP at 5000 RPM by 5 FT.Lbs.
Your engine performance when throttled will be much better, less fuel used, more knock resistance.
I too like Howard Cams as the Owner (Steve) buys ignition products from Pantera EFI. (Competition Products)
The camshafts I have on my site, the shelf items, are ground by Howard Cams on CME cores.
My choice for your needs : TWO choices, one with your springs and the other to be used with PSI1511 ML Springs.
#1 PN# 14328 with 214/232 .600"/.598" 118 CL (Springs required)
#2 PN# 16248 with 216/224 .551"/.553" 118 C/L (Blue Springs)
Power Gains :
#1 = 12 HP Gain at 6500 RPM with same torque as your current camshaft.(Lite Valves Required)
#2 = 2 HP Gain at 6000 RPM with 2 Ft.lb Torque gain at 4500RPM. (Your Cam with a 116 C/L)
Lance
For you, I recommend the Stage 3 LS1 camshaft:
http://www.cammotion.com/camshafts/m...-218-224-16-3/
Customers who bought this camshaft love it!
