pushrod length
So im stuck between ordering the 7.375 or the 7.4's. how big of a difference can these two pushrods make by being that small amount too short or too long I guess is what im wondering. Thanks for input
the expansion of the Aluminum which IIRC will open up the measurement some more. Lots
of reading and opinions on this matter. And when you order tell them how you got the
measurement.
In your case, 7.375 should be fine, but if you want, order both 7.375 and 7.400. Then, if your valve train is a bit noisy, you can swap to the longer ones. Return the ones you don't end up keeping. It's way faster than returning and waiting for replacements.
And FWIW, the stock length is 7.385 gauge length and right at 7.400" on a caliper.
Just for the record, most of the people on the phone at some of the larger vendors (Summit) have no clue what the difference is and really aren't qualified to answer technical questions IMO. I am in awe at some of the stupid answers I have received over the years. I would personally rather be told they don't know the answer than be given a wrong one. Best to verify with your own measurements to avoid confusion and issues.
