Pushrod, lifter preload (math check)
1st) some simple math before measuring, ok old stock cam base circle was 1.55", new cams base circle is smaller 1.45". Difference of 0.1" from old cam to new cams base circle... stock pushrods are 7.4" with stock preload being around .065" or so ( i think). theoretical i should be using 0.10" longer pushrods to get the same preload = new cam would require 7.5" pushrods.
i did port the heads but just cleaned up the decks with Wd-40 and scotch bright pad, there wasn't any reason to clean them up at a machine shop. I also put on new Head gaskets (felpro 26190PT, i called felpro and they told me the compressed thickness of this gasket is the same as the stock gasket compressed thickness, i think it is .50"), i am also using new LS7 lifters.
2) i used my comp cams adjustable pushrod checker to check for correct length and preload.... basically i get with 7.5" push rods 0.0705" of lifter preload. I accomplished this by using the 0 lash then torque to 22ft/lbs method. i extended my pushrod checker 14 turns (starting length is 6.80" + 14 turns (@.050" pr/turn) = 7.5". then i put it in snugged up the rocker to 0 lash, then went to 22 ft/lbs which took 1 and 1/2 turns to reach 22ft/lbs..
sound correct?
also i did this five times to make sure of my measurements and got a little different measurements each time, due to my lack of getting a perfect 0 lash (and it was getting dark on me). the lowest of my five numbers was .0646" and the highest was .07343". If i average all five numbers together I get .06815" lifter preload
sound about right?
Stock pushrods are not exactly 7.400" length according to another user who allegedly took precision measurements.
Hope you used something like brake parts cleaner or denatured alcohol after the WD-40.
As stated above, it appears you are using diameter whereas the actual lifter displacement due to the base circle change should use radius of the base circle. Also, I have measured several sets of stock pushrods and the actual length is 7.385" gauge lengths. 7.400" has been established as stock on the internet but is not correct. I think it is because this is a standard length that is used by vendors for cam swaps. As you can see, the 7.385" to 7.400" difference is 0.015" of gauge length and with a 0.025" radius change of base circle you are within 0.010" of the original stock preload. Note that none of these numbers are absolutely exact but are nominal values.
sound correct?
Not sure how you are getting the preload here. You should open the adjustable to obtain zero lash with the rocker snugged in place and take the measurement. Then add preload.
Don't rely on counting tocker bolt turns, which is what I think you are doing. If you have a dial indicator you can measure directly otherwise use the zero lash method and adding. Using 1-1/2 turns to 22 lb-ft I get a preload of 0.091" using math.
This is normal as there will be differences between each valve, etc. due to tolerances, measurement errors, etc. It is good to verify and make sure there aren't any out of whack though.sound about right?
I do know however, that Manton pushrod length is defined from flat-to-flat (details on this are in their catalog).
If the OP used a Comp Cams adjustable pushrod, then he has measured the "gauge length" that he requires, as the tool is calibrated to their "gauge length" measurement system.
sound correct?
sound about right?
