Help with hp/torque numbers!
Every 6 kpa is like being down 1-psi air pressure.
Other thought is compression. Cylinder pressure and torque curve go hand in hand. You don’t list your compression ratio
Edit: Quick mental math says it was still making 360ft/lbs around 6200rpm to get 421hp.
