226/231 cam to 227/234
On an lq4 6.0 with 799 heads that had the A.I. 226 cc full CNC port work treatment, 10.8:1 CR with a 226/231 duration cam with .605/.598 lift and 113+4............. if I was to swap in a 227/234 duration cam with .614/.576 lift and 113+2, would there be a gain over 10 rwhp?
Th400 auto, 3800 stall, 3200 lb vehicle with 3.73 gears. Thanks
With the 226/231 .605/.598 113+4 cam and the A.I. 226 cc heads, would you think more 1/4 mile accelerating power (not purely a gain at very high rpms) can be gained from heavy milling to gain compression?
OR would a larger cam like the 230/238 .605/.605 114 Advanced Inductions cam make better 1/4 mile and trap mph gains without heavy milling?
3800 stall, 3.73 gears, 3200 lb mustang.
Thanks
Thanks
