Oil pump pickup o-ring
Old Oct 31, 2017 | 11:31 PM
SheepDog209's Avatar
Default Oil pump pickup o-ring
First off, sorry to bring up old stuff. I'm just about to button up my engine build and am somewhat confused as to which oil pump pickup o-ring to use. I'm using a pan and pick up from a GTO for my swap. After all the research I did, I'm still confused, however, I'm pretty sure I need to use the thinner of the two o rings. Being this close to finishing, I don't want to mess up here. Here's a pic of my pickup.
Old Nov 1, 2017 | 12:03 AM
8.Lug's Avatar
The black one. The green one is for pick-ups with a groove in it.
​​​​​​​https://www.performancetrucks.net/forums/attachments/gm-engine-exhaust-performance-21/101788d1501260394-oil-pump-pickup-tube-o-ring-questions-oilpumporing.jpg
Old Nov 1, 2017 | 12:44 AM
The kit I got had 2 black ones... one thicker than the other. I went with the thinner. Hope its right. It seemed to fit ok. Not to hard to get it in.
Old Nov 1, 2017 | 01:29 AM
Rule of thumb is, groove on pickup tube, use fat one. No groove, skinny one. Sounds like you got it right.
Old Nov 1, 2017 | 02:02 AM
Thats the rule I was hoping I got right. Thanks again. Now to get the damper on the crank snout.
Old Nov 1, 2017 | 08:49 AM
moviehall24's Avatar
Recently my car oil pump damage.
When i am driving my favorite car.
I am need to suggestion to how to safe my oil pump.
Old Nov 1, 2017 | 10:20 AM
You are right!
Old Nov 3, 2017 | 08:38 AM
scott750's Avatar
Any reason behind why GM made 2 different oil pickup tubes with and without an indent? Seems it would have taken all the confusion out with 1 style tube and 1 o-ring.
 Michael S. Palmer
Old Nov 3, 2017 | 10:17 AM
One might have evolved from the other.
Old Nov 5, 2017 | 06:52 AM
RockinWs6's Avatar
INSANITY, I suspect the engineers were snorting crack when they put a ORING in dirty nasty acidy engine oil. Seriously I don't snort crack and I wouldn't think of it. This oring and the unsealed windshield cowlings have destroyed more engines than you can imagine.
Old Nov 5, 2017 | 09:58 AM
patSS/00's Avatar
The original o-ring in mine was fine after almost 18 years.
