Btr vs Tsp cam
Old Nov 1, 2017 | 01:01 PM
Tuck Capo's Avatar
Default Btr vs Tsp cam
Need a little advice. Lq4 with 243 heads going in a 5000lb vehicle with a 2500 stall. Cams I'm looking at are tsp stage 2 truck cam or btr stage 2 truck cam. I want/need low end torque. Is one of these preferred over the other? I think I'm in the right ballpark as far as cam size as it will be a dd with some track & towing time. Any advice is appreciated!
Old Nov 1, 2017 | 01:21 PM
Tuck Capo's Avatar
The Specs are 212/218 .553/.553 113+2 on the btr and 212/218, .550/.550 with a choice of 111-114 on the tsp.
Old Nov 1, 2017 | 01:33 PM
If you go BTR have it ground on a Cam Motion core for best quality. Other than that the only difference between the two is the LSA. If you get the TSP with 113LSA they would be identical except for whichever advance TSP puts on theirs. The +2 advance BTR has will give you more low end. Call TSP and ask how much theirs is advanced. Their website doesn't say.
Old Nov 1, 2017 | 03:17 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
As a standard the 212/218 is a 112+2. That's how it's sold normally but can be changed to what anyone wants.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
