LS7 Lifters going in Hard, had to tap them in
Have already installed a BTR Stage l twin turbo cam, new oil pump, then the sticky lifters. Holding off on bolting on new LS9 head gaskets and assembled LS1 heads with BTR platinum spring kit and new pushrods until I feel good about these questionable lifters. Plan on using the stock bottom end of the 5.3.
Note: the old ones (lifters) were not too easy to get out. Why I bought the special tool.
Those ebay ones are the cheap Eaton body Johnson's. They arent high lift anything just cheap. $60 set of lifters really or less.
Delphi is the lifter youd want. Its the actual "ls7" lifter.
Do the parts actually have GM part numbers? If not, they the quality is unknown and I would be very concerned about using them.
Sidenote: make sure to not rub them too much befor putting em in. Only bad things can happen i hear.
Also dont soak em in oil. Just break the roller free lube the roller and the body with a nice moly lube, and put a dab in the pushrod cup. Thats it.
