Lets play the guess what happened game.
Old Nov 20, 2017 | 11:17 AM
1FastBrick's Avatar
Here is a better picture of the rod and bearing from cylinder number 2.
I already picked up 2 rods and pistons.
Attached Thumbnails Lets play the guess what happened game.-20171120_091001.jpg   Lets play the guess what happened game.-20171120_091013.jpg   Lets play the guess what happened game.-20171120_091055.jpg
Old Nov 20, 2017 | 03:21 PM
RockinWs6's Avatar
Realize you are just a over boost away from carnage........................
Old Nov 21, 2017 | 12:10 AM
Karlw's Avatar
I swear if I stare at that last pic long enough I can see the bend.
Old Nov 21, 2017 | 12:20 AM
1FastBrick's Avatar
Which way...
Old Nov 22, 2017 | 08:55 AM
dreadpirateroberts's Avatar
Originally Posted by 1FastBrick
Bent rod is the answer.
appears to be approx .050 shorter.
It appears to have side loaded in the direction of the pin.
Now, the tuff decision. Should I reuse the 2 pistons and just replace the rod or should I put a piston and rod in those 2 holes???
i would replace the rods, wrist pins, and pistons. no question.
the problem is the rings/cyl walls are worn in. new rings won't seal.
the other thing that would worry me is the stress on the crank when the rods bent. you should at least have that checked.
so, you are probably looking at a rebuild if you want it done right. In addition, you're obviously running on the edge of what those rods can handle. sounds like it's time to upgrade.
i can't tell what version of OEM rods you're running, but it may be worth considering finding a used gen IV bottom end with the newer style rods and just swapping stuff out.
Old Nov 23, 2017 | 09:47 AM
Crf450r420's Avatar
lay the rod on something flat and to see if it looks bent. We have found them that way before. Also measure the piston you could have rolled the skirt and be hearing piston slap.
