Lets play the guess what happened game.
Stock LQ4 bottom end with floating rods. Engine saw a boost spike. Started making a tapping like a bad lifter. Engine was shut down right after but has been started for diagnosis.
No sign of dentenation, No misfires, No spun bearings or damaged rod pin bushings, No butted ring lands, no metal in oil, rods look fine, piston looks fine other than where it came in contact with crank. Bore looks fine too.
Only damage is bottom of piston hitting high spot on crank counter weight. This is on number 2 and number 7 cylinders only. I also should note those to pistons come up short from reaching the top of the deck like the other 6.
Any one ever see anything like this???
Every thing looks good as far as I can tell. I honestly thought there would be something other than what I am seeing.
My experience is with the EJ-25 Subaru engine when detonated.
The rods bend with to visible damage to the piston.
Lance
appears to be approx .050 shorter.
It appears to have side loaded in the direction of the pin.
Now, the tuff decision. Should I reuse the 2 pistons and just replace the rod or should I put a piston and rod in those 2 holes???
