Keep cracking heads!
Old Nov 25, 2017 | 06:32 PM
Silverado87k's Avatar
Default Keep cracking heads!
Hello all Im new to this forum. I signed up hoping I can get some help on my problem. I have a 04 Silverado with a 5.3. First Chevy truck I have ever owned. At 200k the truck slowly started losing water and I discovered it was a cracked head. Cracked right by the cylinder head bolt. It had the 862 heads on it so thats what I replaced them with. (I hear they are the best option)? I used all good parts. Factory gaskets and I used ARP head bolts because factory bolts were ridiculously expensive ($350). Well 6,000 miles later. One of the new heads cracks. AGAIN. The head is under warranty. But this is bs. I dont want to constantly be wondering when its going to happen again. Does anyone here know of a better set up or a solution? Without spending crazy money? Im really not impressed. I am very meticulous when it comes to working on my vehicles. I know I did it right. Please give me some imput!
Old Nov 25, 2017 | 07:17 PM
KCS's Avatar
KCS
Moderator
Did you research his problem at all? It's well known to plague the Castech castings, which are identifiable by a battery logo cast in the rocker arm area.
Old Nov 25, 2017 | 07:48 PM
Yes I researched it a lot when I replaced the heads the first time. The original heads were not castech. And the rebuilt heads I installed were also not castech. Do I just have really shitty luck? Should I have used stretch bolts instead of ARP? Are these heads just a shitty design?
Old Nov 26, 2017 | 02:09 AM
99 Black Bird T/A's Avatar
What condition is the truck's cooling system in? Did the truck ever overheat?
Often vehicles have other issues like head gaskets etc due to a compromised cooling system.
Dex-cool coolant if it's not changed eventually starts to clump and can impede flow in the radiator.
Old Nov 26, 2017 | 03:06 AM
SheepDog209's Avatar
Make sure your deck is flat if you pull the head off again. And I agree with the cooling system. Maybe flush it. I'd replace the temp sender to ensure its reading properly. Cheap insurance.
Old Nov 26, 2017 | 07:02 AM
RockinWs6's Avatar
Did the head crack in the same area? Pictures of both heads would help.
Old Nov 26, 2017 | 09:29 AM
I bought the truck with 194k on it. And it had the green coolant in it that looked old. (More yellowish). So I flushed the system really well and put dexcool back in it. I have a feeling the original head had a crack already, and when I flushed the system the crack started leaking. The truck has never gotten hot since I have owned it. A little warm maybe but not hot. And yes same head cracked this time by the bolts. First time one cracked by only one bolt, and this time its by 2 of the 3 center bolts for sure and the 3rd looks like its starting. Ill get some pictures this morning. Last night I sprayed the areas by the bolts with brake clean and then put 15psi to the coolant system and watched the cracks show coolant seep.
Old Nov 26, 2017 | 10:19 AM
Also should I have used stretch bolts instead of ARP? And if the block is warped what do I do? Junk it and get a whole new junkyard engine?
Old Nov 26, 2017 | 11:01 AM
vettenuts's Avatar
The ARP bolts will be fine. The stock TTY bolts are just a different method of preloading the bolts. Just make sure the holes are super clean and use the ARP lube for an accurate preload based on torque.
Old Nov 26, 2017 | 11:58 AM
Jimbo1367's Avatar
I'm betting if you have good heads, its cracking because of the block isn't flat.
Old Nov 26, 2017 | 01:51 PM
RockinWs6's Avatar
Yeah I'd bet the deck is way out of whack.
Old Nov 26, 2017 | 02:04 PM
I tried posting pictures but they arent up yet for some reason. If the block is out then I guess start over with a short block or whole engine. If the block isnt bad then I just have real shitty luck? What straight edge can I use to check it? Anything thats really straight? Ha. I dont have 24 parallels laying around.
Old Nov 26, 2017 | 04:55 PM
Most people have a level handy... they work... if you don't want to junk the engine, a machine shop can deck the block for you... probably needs to be bare tho... it's usually done during a rebuild.
Old Nov 27, 2017 | 09:42 AM
pantera_efi's Avatar
Default DeckPlate+ValveSeatRound
Hi Silver, YES it is better to fit a fastener that will stretch the correct amount, the amount the AL head was designed to grow keeping the clamping pressure constant.
My method when ARP is specified, by the customer, is to UNDER CUT the bolt/stud to match the original bolt stretch.
I was the one who had the task to install the Deck Plate to the head and tighten it correctly when I worked at HMS. (1970)
I then carried the head to the man, Wally Cartwright, who cut the seats.
WE had learned much about a cylinder head being damaged by TOO much clamping force.
WE found the valve seat would go "out of round" when deck plated vs bench ground.
WE fit "pressure paper" between the head/plate and the head/crankcase.
The "paper" changed color with a report of pressure force then known.
I too agree their may be other problems, I would go to Harbor Freight and BUY a straight edge for crankcase measurement.
Lance
Old Dec 18, 2017 | 09:01 PM
Default Head number 3
Ok everyone I replaced the head and have put 1000 miles on it. Started using a little water right off the bat. Real slow. I thought maybe it was an air bubble working its way out. Nope! 3rd head is cracked. And I checked the block. It is perfectly flat. I used a starret 24 straight edge and feeler guages. I dont know what is going on. Im almost starting to wonder if its the head rebuilder doing a shitty job or the heads are already cracked when I get them? He runs a reputable shop tho rebuilding thousands of heads. I have a hard time thinking his shop is the problem. I dont get it.
Old Dec 18, 2017 | 09:09 PM
MY_2K_Z's Avatar
Get some good used heads on Craigslist or something don't get some already destroyed and "rebuilt" heads from some hack.
Old Dec 18, 2017 | 09:48 PM
qweedqwag's Avatar
I'm with Jimbo on this one.
Old Dec 18, 2017 | 10:01 PM
Could it be the steam vent?
Old Dec 18, 2017 | 10:45 PM
Yeah I dont know. But this is ridiculous. Im really not impressed. Im going to look for a head somewhere else. I just dont know how it could be this shitty. Hopefully the head rebuilder refunds me. I wish someone casted a better head for these engines. (That dont cost a fortune) 3 heads in a row make me feel like this just going to happen again no matter what. If it does Im getting rid of the truck
Old Dec 19, 2017 | 12:20 AM
MY_2K_Z's Avatar
You don't need better cast heads, you just need some that aren't already fucked.
