Does my timing look correct? Never done this!
Old Nov 29, 2017 | 07:08 PM
MistakenGeneral's Avatar
Default Does my timing look correct? Never done this!
Looking for input, I will fix whatever is necessary. I believe I have it straight up and down, or should I look for a better angle than looking down into the bay?
Attached Thumbnails Does my timing look correct? Never done this!-24129856_1705423622825821_8192256978022679721_n.jpg
Old Nov 29, 2017 | 07:15 PM
dreadpirateroberts's Avatar
i can't see the dot on the crank sprocket.
Old Nov 29, 2017 | 07:22 PM
It looks like a shine actually, but it's a 0 right under it that I tried to make appear easier to the eye with a white mark. I can circle it and re-upload.
Old Nov 29, 2017 | 10:16 PM
Is it the tooth DIRECTLY under the marked cam tooth? If so the timing is right!
Old Nov 30, 2017 | 06:29 AM
vettenuts's Avatar
Can't see it either. Shoot from a slight angle or don't use the flash if it went off when you took it.
Old Nov 30, 2017 | 06:41 AM
I’ve got the same timing set, and it’s tough to see the zero, even in the shop sitting right in front of it.
Old Nov 30, 2017 | 07:18 AM
KCS's Avatar
KCS
Moderator
The only way to tell if the timing is correct is to degree the cam. I just degreed the custom ground cam in my 4.8L and it was off 2 degrees, even though it was "dot to dot" on the timing set.
Old Dec 1, 2017 | 08:57 AM
Old Geezer's Avatar
 Michael S. Palmer
Old Dec 1, 2017 | 05:59 PM
00pooterSS's Avatar
If your dot on the crank gear is at the white mark then yes you got it.
I've read several posts recently where cams were ground off a little so I agree degreeing the cam should be done.
But as far as dot to dot, you got it.
