Bronze bushed rocker trunions
Old Dec 11, 2017 | 07:36 AM
farmington's Avatar
Default Bronze bushed rocker trunions
Now that the Straub and CHE bushing kits have been out for a while, for those of you that have actually used them, what are your opinions? Anybody put 10,000 miles with double springs on them and taken them off and inspected them? Wondering how they are holding up long term.
Old Dec 11, 2017 | 11:22 AM
Jimbo1367's Avatar
Both are good from what I've seen. But I would/will go with CHE
Old Dec 11, 2017 | 11:36 AM
Is that because the CHE "floats" the bushing as opposed to the Straub being pressed in? I can agree with that...
Old Dec 11, 2017 | 06:31 PM
cookseyb's Avatar
I used Johnson brothers and was impressed with them. All the bushings need soaking in oil or set them on your thumb, fill with oil and use your index finger to pressurize the bushing with oil. They are porous and this will add alot of time to their lively hood. Learned this from re building generators and starters.. FWIW
Old Dec 12, 2017 | 07:51 AM
farmington's Avatar
just wondered that since these aren't directly oiled how they would last. Familiar with using bushed rockers with big block Mopars but those were pressure oiled and lasted forever.
Old Dec 12, 2017 | 11:30 AM
There's usually enough oil spilling off the pushrod hole to bathe the bushing in sufficient oil to keep it healthy. The only thing that will kill a bushing is if a pushrod clogs.
