Ported 243 or Aftermarket??
Lot of people still running the 10 bolt in there auto car including myself. 3.73's and 1.5x 60's here in mine
Otherwise with suspension work and weight reduction LOW 11s is at the finger tips.
Flow numbers are really easy to check. Everyone lists flow numbers on their website.
I just got my LS1 heads back this morning from another vendor that I thought offered a better package. They look like brand new. Gotta love it!!
Also, you should just send in your 241 heads. Once ported, there isn't a difference from the 243 heads.
On the other hand, just taking the used 243 castings in for a good 5 angle valve job would give him flow numbers flirting with a 20% improvement over the 241. Add in .030 milling job and all of a sudden you have a worthwhile mod.
You may want to consider Cometic .040 HGs to increase CR and tighten the quench height to increase squish and add further power. Otherwise you are good to go and will enjoy the difference.
243 heads 64.45cc chamber volume CR 10:5:1 intake port 220cc exhaust port 75 cc.
The 243 shortens burn time and uses less ignition timing advance to produce the same power, less timing allows a more efficient combustion, the 243 produces more torque, the d shaped exhaust port improves flow. Milling the deck .030 will yield an approximate CR of about 11:1:1 on an LS1 engine. So ported and milled, ya they are better than a ported 241 will ever be, do it.
