5.3 truck
Old Dec 20, 2017 | 10:35 PM
Adrian Leal's Avatar
Default 5.3 truck
I have a 02 silverado with a 5.3 with the xr275 cam with bolt ons and a fti 3200-3400 torque converter and i recently bought a set of 243 heads of a 08 5.3 along with the intake with injectors and fuel rails and im slapping on a 92mm tb on it. But would it work if i just port the exhaust port on the head instead of the whole head since of the D shaped exhuast port
please lmk if you guys can if it'll improve performance
Old Dec 21, 2017 | 04:13 PM
00pooterSS's Avatar
You don't need to port it because it's a D. Leave it.
Old Dec 21, 2017 | 04:16 PM
So it affects it if I just make the exhaust port bigger
Old Dec 21, 2017 | 04:43 PM
00pooterSS's Avatar
I'm really not sure what you're asking.
It seems like you're asking if you need to port it because it has D shaped exhaust ports
I would port the intake and exhaust or not at all. If I had to choose one side to do I would do the intake side.
Old Dec 21, 2017 | 04:50 PM
I wanted to port out the heads but i dont know anyone near me who will port them out so I was thinking about porting out the D shaped port myself at home. what I wanted to know if it'll affect its performance of it
Old Dec 21, 2017 | 04:56 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Dont port. at all. mill .012-.018 off and get a good valve job and thats it. No need to waste time for minimal gains.
Old Dec 21, 2017 | 05:01 PM
Oh ok cause they had told me to shave them down .30mills cause of the low compression of the 5.3
Old Dec 21, 2017 | 05:05 PM
.030 is too much imo. .018-.020will give you roughly 61cc or so. Thats enough for good pump gas.
 Michael S. Palmer
Old Dec 21, 2017 | 05:57 PM
Ok and what's the original cc of the 706 heads cause they told to shave them down .30mills so I could get the same compression as the 706 does
Old Dec 21, 2017 | 06:00 PM
Cutting too much off the chamber will effect flow also.
706 heads are about 61cc
Old Dec 21, 2017 | 06:09 PM
Oh ok cause the only thing I want is for the compression to stay the same as how it is with the 706
