Time to pull the head?
Old Dec 25, 2017 | 10:05 PM
dreadpirateroberts's Avatar
with as much travel as there is in the stock lifters, i don't think a difference on the measure of a few thousanths would bend a pushrod if his preload was set correctly to begin with. there's more variance than that between each lifter/pushrod/rocker combo, and there's more expansion than that when the engine reaches operating temp vs cold.
if his lifters were almost bottomed out, or he was running solid lifters, maybe i could see how it could.
Old Dec 25, 2017 | 10:17 PM
Agree 100%, but perhaps the pushrod bent when the rocker puked it’s bearings?
Old Dec 25, 2017 | 10:21 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
I’m not ignoring anything guys. I simply SUGGESTED to START with measuring pushrod length, to ENSURE that the rocker geometry, and cup location is kosher.
I never said that’s absolutely the problem, I simply said that’s where I’d start. You know as well as me that it’s virtually Impossible to diagnose issues like this over the net. It’s probably not the issue...but it could be...it’s a free easy simple step, and that’s where I’d start. AND THEN I’d look at at other issues once I ruled this out.
Didnt mean to sound like a dick. If i did, i apologize. The way you said this is clearly mechanical though rules out alot of electrical issues that could be the problem also.
The window inside the ls7 lifter at least for preload is pretty wide and is usually the safety net that people do not realize they are relying on when they put pushrods in.
Some people like to use .080-.100 on them. Seriously thats been put here on tech many many times.
But i do agree it is a simple test, can be done without pulling heads etc, and would be a good check anyway.
Old Dec 26, 2017 | 06:00 AM
chevymec's Avatar
When you said you found a needle bearing in the push rod hole, did you mean in the head or the center of the push rod?
Old Dec 26, 2017 | 07:36 AM
01ssreda4's Avatar
Why would a post like this, make you want to punch your computer screen? Chill bro...stop punching stuff.
Op changes his rockers, and now has backfiring out of the exhaust.
FIRST inclination is that the valves aren’t closing. Remember that we are working with a non-adjustable valve train. I like the guys at WS6Store, and I buy from them, but maybe something is a little off? I understand variances from hydraulic lifter preload, I really do. Install too long a pushrod in your engine, go out and run it hard and you’ll likely have the same issues.
And your suggestion is to run a diagnostic, when this is clearly a mechanical issue?
Maybe my SUGGESTION to have the op check his pushrod length is out of line?
Call me crazy, but that’s where I’d start...
THEY ARE STOCK REPLACEMENT ROCKERS
reread the above, 12 times.
Originally Posted by RevGTO
Out the exhaust.
No we didn't. The valvetrain is all stock and original.
Old Dec 26, 2017 | 07:51 AM
vettenuts's Avatar
I would check compression on that cylinder at a minimum as others have suggested. With that many bearings missing the valve train really couldn't control that one valve and it may have tagged the piston. I assume you looked down the pushrod hole for needle bearings, but a pushrod sitting on a bearing wouldn't be good either. If the compression is good then at least the mechanicals should be good and I would tend to look more at fueling and spark if compression is OK.
Not sure I saw it, was the bad rocker on the intake or exhaust valve?
Old Dec 26, 2017 | 10:40 AM
RevGTO's Avatar
Pontiacerator
Spark issues will show up around there also and can cause that, so can fueling. What does actual afr show per bank?
I haven't put a wideband on it (yet). My fuel trims are spot on and we haven't detected any electrically induced misfire, leading me to think that the issue is in the valvetrain.
It was the frontmost rocker on the passenger side - #2 cylinder - exhaust. We put a magnet down that pushrod hole and pulled out one needle bearing.
Old Dec 26, 2017 | 11:41 AM
RonSSNova's Avatar
I would do a leakdown Test. It’s more informative than a compression test.
Old Dec 26, 2017 | 12:53 PM
that's more reasonable, considering the rocker might have bound up on the trunnion when said puking happened.
Old Dec 26, 2017 | 02:07 PM
RevGTO's Avatar
Pontiacerator
Good point.
Old Dec 26, 2017 | 05:41 PM
00pooterSS's Avatar
If I read this right it was doing it before the rocker swap and after. I'd look elsewhere than the rockers, especially considering they are stock units and locations should remain the same. The hydraulic lifters will make up for small variances in push rod length needed, if any was needed, and I'd say there isn't any in this case.
The bent push rod is a bit more telling, the pop out the exhaust and the bent pushrod (assuming it was on the exh valve?) would make me think the exhaust valve or spring is suspect and the mixture is lighting off with an exh valve that isn't sealing or is open. That or maybe you're loosing valve control at upper RPM (weak springs).
First thing I would do is pop the rockers off and stick air pressure in that hole and listen for air to come out the tail pipe. If you're capable of viewing data check your basics, fuel trim etc, but I doubt that'll be the culprit. I have cars come in all the time with whacked out fuel trims and they don't backfire or sneeze. Backfiring or sneezing is always a timing issue, or a valve open during the light off of the mixture (timing off or valve not sealing same thing)
Old Dec 26, 2017 | 11:45 PM
  #32
i am wondering if poor valve control from weak springs led to side loading the rockers, making the end caps fail, which lead to the needle-bearing-puke.
or, perhaps the valve stem is slightly bent and the exh valve isn't seating all the way.
Old Dec 27, 2017 | 11:31 AM
  #33
00pooterSS's Avatar
I'm glad you posted that it reminded me of a car I had an issue with in 2014. I have seen a rocker on a Chrysler 300 move on it's shaft a little due to wear and cause the valve to not seal. I did not ever find the root issue though. The car had a misfire and a valve train noise. I pulled the valve cover and saw the rocker was worn and moved to the side, this was a shaft mount style and the rockers wore into each other (they keep each other in place). I replaced the rocker assembly and the car still misfired so I ran a compression test on that hole and found it had low compression. Somehow the rocker moving caused some sort of damage to the valve to where it didn't seal. Unfortunately I didn't have time to pull the head down and inspect it. My service writer ordered me another head and I slapped it on and the car was perfect. I was quitting that job that day and finished that car and that was it so I never had a chance to inspect the valve. I assume it bent the valve from pushing on the side of the tip for a period of time, but it's just an assumption.
Sounds like what has possibly happened here. OP you may need to pull that head a slap a valve in it. Lap the new valve in and run it. After a compression and or leak down check of course to verify there is a valve issue.
01ssreda4 posted a lap in vid recently if I recall correctly if you wanna search his posts and check it out, in case you're unfamiliar with lapping valves.
Old Dec 28, 2017 | 08:18 AM
  #34
01ssreda4's Avatar
A controversial thread on some forums btw (my lapping valves method).
Old Dec 28, 2017 | 12:16 PM
  #35
00pooterSS's Avatar
Controversial? Really? It's a tried and trued method, been around since the dinosaurs.
Old Dec 28, 2017 | 11:22 PM
  #36
RevGTO's Avatar
Pontiacerator
Yep, I'm familiar with valve lapping in old school applications. Not so much in the LS context, though I think I did see the thread about it.
Leakdown test was done on the affected hole this morning. Came in at 13%.
Tomorrow I have some time to mess with it, so I'm thinking to do two more procedures:
1. Scan individual cylinders for misfire at speed.
2. Check other pushrods.
The key thing to remember here is that there were no driveability issues (backfiring, rough idle) while the bad rocker was in there. It was only after the replacement that all these issues arose.
Old Dec 28, 2017 | 11:27 PM
  #37
I would do leakdown on the cyl across the engine from it. 13% is within "range" but may be high compared to the others.
Old Dec 30, 2017 | 09:23 AM
  #38
01ssreda4's Avatar
I hate when your mind does that, forces you to accept something as 100% truth. It makes finding the real truth so much more difficult because you chase shadows. My single best piece of advice is stop focusing on that rocker arm. You have a misfire, find it. No more, no less. Prime example is you did 1/8th of a leakdown test. If you had the rocker out of your mind you would have done it complete and have much more valuable info to work with. My .02.
Old Dec 30, 2017 | 11:43 AM
  #39
RevGTO's Avatar
Pontiacerator
Scanned for misfires yesterday and found random misfires on multiple cylinders. The counts went up as the car got progressively warmer, which you can notice just by driving it. We also redid the torque sequence on all the rockers to make sure we got it right. Still having rough idle and backfiring at higher rpms.
Next stop is to inspect for bent pushrods and needle bearings in all the holes on bank 2, and if we find the former, then on all 8.
Old Dec 30, 2017 | 11:51 AM
  #40
When looking for misfires you cannot just say we have some and go on. There is so much info there. You need to look at history and current misfires. Target them and see if you can single out what is causing the issue there. Then look at the cyls with the worst misfires. Adding a cam will cause some "misfires" but normally a tuner will soften them up. If you show misfires but no service engine soon light, then the tuner turned them off...which is never good.
If you are having issues at wide open, then stay away from it during testing and until youve figured it out. All of your testing can be done at idle and mild throttle.
