Cam choice for a stock LQ9
Old Jan 24, 2018 | 03:01 PM
Uranium238's Avatar
CARB smog friendly?
Old Jan 24, 2018 | 04:55 PM
Originally Posted by Uranium238
CARB smog friendly?
Tech@WS6store claims about 3 or 4 have passed smog here in Calif. with the HiLift Hot Cam. I wonder how, with the lopey idle it has. I guess as long as the OBDII readout is good, maybe they look the other way.
Old Jul 28, 2018 | 04:04 PM
99 Black Bird T/A's Avatar
Regarding smog testing and the GM Hotcam -
Hot Cam specs 219/228@.50 .525/.525 lift 112 LSA
A friend put this cam in this 99 SS Camaro and back in 2001 it failed the sniffer test and his car failed emissions repeatedly. He finally ended up selling the car due to the failed smog test issues. The hydrocarbon count was too high even with cats and tuning. With today's much better tuning it might help but I would want to find someone thatschad a hot cam pass the same emissions testing routine your car will face. The 112 LSA is hurts the sniffer test.
A 224/224 114 LSA will normally pass a sniffer test with a good tune in a LS1.
Old Jul 28, 2018 | 09:56 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Our high lift hot cam on a 114 passed basically a hearing test and emissions in Germany. We have had a few people from Cali grt them but it is VERY difficult to get feedback.
If you want to drop hydrocarbon emissions you can change the timing and afr in the areas that a clayton etc dyno would run. most of the time its idle and then some smooth accel and decel and not aggressive so WOT/PE isnt even an issue.
I helped on the GM Challenge X project with their hydrogen fuel cell equinox and we did so many drive cycles on the mustang dyno with the sniffer hooked up it was ridiculous.
If you have NOx issues then just turn the timing down to decrease cyl temps/heat and put a cooler stat in.
Old Jul 30, 2018 | 09:31 AM
93Polo's Avatar
Originally Posted by tech@WS6store
The Texas Speed STG2 low lift truck cam is what id recommend. Runs $389 for cam AND springs. Uses stock pushrods. Great pickup in tq. Anything above that would really not be what you want.
http://www.texas-speed.com/p-1158-ts...e-springs.aspx
If you are looking to use it as a truck, and pulling trailers I like a low lift truck. I would also call Cam Motion.
What kind of use will the truck see? Daily, pulling trailer, street toy with an occasional trip to the drag strip?
What is he willing to spend on springs, and will he be willing to change springs down the road? How many miles does the truck see a year?
Old Jul 30, 2018 | 11:07 AM
I agree. Both Cam Motion and Texas Speed & Performance are on top of the LS truck cam situation. Either would be very helpful to you.
Old Jul 30, 2018 | 02:01 PM
The high lift is the best in any situation vs low lift. I run them in both my 2500hd trucks. And i haul alot. also DD them.
Save up a little more money and get the high lift
Old Jul 30, 2018 | 03:29 PM
93Polo's Avatar
How long do you go on springs and which springs do you recommend?
I am tempted to drop some 243s I have sitting around on my '01 2500HD. It is a daily which does pull a car trailer from time to time.
Old Jul 30, 2018 | 05:10 PM
Those heads and a good truck cam will make your truck come ALIVE! Either WS6store or Cam Motion can help you with whatever you want to do.
Old Jul 31, 2018 | 12:28 AM
Forever really on those lobes.
Have you ever seen or actually heard of someone testing their springs on the reg even with super aggressive cams unless something happened?
No need to worry here.
Old Jul 31, 2018 | 02:45 PM
93Polo's Avatar
Actually I have but good to hear.
