Cam choice for a stock LQ9
He was thinking of the GM hot cam kit, but I haven't heard much about that cam on an LQ9.
Any recommendations for a cam if not the hot cam kit from GM?
Aside from the 224R from TS, what other cam brands are good options? We would like to avoid any changes to pushrods, but are open to spring upgrades, like the PAC 1218 or 1518.
http://www.texas-speed.com/p-1158-ts...e-springs.aspx
If you are going through the effort of getting a new cam and springs, why not install a set of chromoly pushrods while you are at it?
I built an LQ9 recently and wanted a little larger cam, but nothing too wild as this is a daily driver ONLY.. Meaning NEVER will it be raced. NEVER will it be beat on. The cam I got has the LS9 specs for the LSA engine-same lift & duration, but on a 115 lobe separation angle as opposed to the factory LS9 cam sep angle of 122. It has ZERO lope. It does produce quite a bit of torque down low and this combination is much faster than my sons 5.3/Hot Cam setup. Keep in mind it will idle like stock, drive like stock-just make a bit more power. If you truly want that choppy idle sound-the cam I have is NOT for you.
Please post back and let us know what cam you end up getting and how you like it.
Will 243 heads and the GM hot cam be compatible together? Valve clearance ok? I assume I need to change the push rods out too now.
I would just surface the heads at .005-.006 and be done.
