Opinion on my build needed
Old Jan 30, 2018 | 05:19 PM
Jas2730's Avatar
Originally Posted by HCI2000SS
Interesting choice. Did you get them used?
No. Purchased them new from Texas Speed today. I was looking at spending around $1200 on the 5.3 heads after shipping and having 3 damaged exhaust manifold bolt holes helicoiled. Got the 225's for $1780 with sodium filled valves, minus valve springs as I already have a BTR kit.
Old Jan 30, 2018 | 05:23 PM
HCI2000SS's Avatar
Gotcha. I don't hear a lot on those heads, but what I do hear is generally positive.
Old Jan 30, 2018 | 05:26 PM
Jas2730's Avatar
Deciding factors were they flow slightly better than the stage 2.5's, come with 62cc chambers off the shelf and more room to grow if I ever wanted to have them ported.
Old Jan 30, 2018 | 05:29 PM
HCI2000SS's Avatar
Yep and those are all great points for sure. You throwing them on soon?
Old Jan 30, 2018 | 05:36 PM
Jas2730's Avatar
Yeah. I'll start assembling everything next week.
Old Jan 30, 2018 | 05:42 PM
Jas2730's Avatar
Well maybe this weekend. Just got a shipment notification that they're arriving Friday.
Old Jan 30, 2018 | 05:49 PM
HCI2000SS's Avatar
Cool. Let us know how it goes. Then off to a competent tuner I assume?
Old Jan 30, 2018 | 05:55 PM
Jas2730's Avatar
I'll street tune it myself then put it on the dyno for the final dial in.
Old Jan 30, 2018 | 05:58 PM
HCI2000SS's Avatar
Good deal. Saves a few bucks as well
Old Jan 30, 2018 | 06:00 PM
Jas2730's Avatar
If I ignore what I paid for the hp tuners software and accessories a few years back . Lol
Old Jan 30, 2018 | 06:06 PM
Billiumss's Avatar
I'm building a low mile, stock bottom end 2005 LQ4 to replace the blown LS1 in my 1998 Camaro SS. I would like some input and opinions on my combo. I will list the parts I have already purchased first, followed by the remaining parts i'm leaning towards purchasing second. Any input is welcomed. Thanks.
Purchased
BTR .660 springs
BTR trunion kit
PRC as cast 225's
Tick Polluter Cam .635/615 239/244 112
Morel 6504 lifters
Melling 10296 high pressure oil pump
LS2 timing chain
SLP 25% UD harmonic balancer
ARP balancer bolt
ARP head bolts
all new GM gaskets
Parts to be purchased?
Chromoly pushrods
Fast 92 intake
Nick Williams 92mm tb
Racetronix 255 w/ hotwire kit
Deatchwerks 42lb injectors
You might want to get the Melling 10295, the 10296 might suck your pan dry.
The 10295 is 10psi over stock pressure. I've been using them for years.
Old Jan 30, 2018 | 06:27 PM
  #32
Jas2730's Avatar
Oops. Made a typo on the part #. Yeah, I don't want the high volume, just the high pressure.
Old Jan 30, 2018 | 07:01 PM
  #33
cookseyb's Avatar
You might want to re think the SLP 25% under drive pulley I had one on mine and I spent several years and thousands of dollars trying to figure why my knock sensors were pulling timing out at higher RPM! Went back to stock Harmonic Balancer and all was well JUNK Parts
