Valve Clearance Issue?
Old Jan 29, 2018 | 06:10 PM
MonochromeSS's Avatar
Default Valve Clearance Issue?
Wondering if should I even bother checking valve clearance. Milled my 317 heads ~.030. Originally they were ~76cc now they're ~70cc.
I have -26cc dished pistons with valve relief.
Heads have 2.10" intake valves.
Cam is pretty mild .581 lift, 224intake, 220 exhaust, 116lsa.
.051" MLS gasket.
I'm thinking I don't need to worry about it. I was already running this setup before the .030" mill.
Thoughts?
Old Jan 29, 2018 | 06:36 PM
NEstyle's Avatar
It doesn't take much longer to check than it did to start this thread. Just do it.
Old Jan 30, 2018 | 03:31 AM
HappySalesman's Avatar
Check it. It will save you from starting a thread later on saying "My motor is trashed"
Old Jan 30, 2018 | 08:45 AM
KCS's Avatar
KCS
Moderator
I would check it, but I'm 90% sure that you have miles between the pistons and valves.
Old Feb 17, 2018 | 05:52 PM
Just following up on this for anyone who finds this post years from now. Checked it. Tons of clearance. Even at TDC I have ~.400 of clearance when both valves are closed.
Old Feb 17, 2018 | 05:59 PM
Karlw's Avatar
You mean open, right?
Old Feb 17, 2018 | 06:54 PM
NEstyle's Avatar
Piston to valve clearance is tightest around 9 degrees before and after TDC. Checking at TDC is of no use and doesn't tell you anything.
Old Feb 18, 2018 | 09:42 PM
Checked there too, but no cam is opening >.400" in 15 degrees.
Closed to fully open is ~.400"
