Hole in head
Old Feb 4, 2018 | 03:11 PM
epfatboy's Avatar
Default Hole in head
So how might I fix this,
#6 header bolt was wankie so I thought I'd helicoil it... guess it was a smidge closer than I thought to the exhaust chamber.
What sucks is this is a set of AFR heads.
https://photos.app.goo.gl/RHcWJ86g0F29h4HD3
Old Feb 4, 2018 | 05:59 PM
cookseyb's Avatar
Send it back to AFR for repair and re-drilling the hole and taping it. Put Fel-Pro N1000 on all the exhaust bolts.
Old Feb 4, 2018 | 07:24 PM
cookseyb's Avatar
Or tap it to the largest aluminum bolt that will fit, cut it of, file it flat,f and drill and tap to the proper size. Be sure and locktite r the bolt.
Old Feb 4, 2018 | 09:01 PM
qweedqwag's Avatar
I'd send it back to AFR or at least call them and see what they say.
Old Feb 5, 2018 | 06:09 PM
epfatboy's Avatar
Consensus is to throw the helicoil in it and run it
Old Feb 5, 2018 | 06:19 PM
The Cartel's Avatar
Local machine shop can weld it up and retap for cheap I'm sure. **** a helicoil
Old Feb 5, 2018 | 09:23 PM
slogo's Avatar
It'll leak. I have helicoil then put some jb weld in, it did not leak, that was
not my decision. I wanted to pull head and have it welded, he did not want to
spend money.
EDIT: just reread, thought it was a coolant jacket, I would try just Helicoil, worse thing is
you have to do it right if it doesn't please you.
