Do it all cam
Old Feb 12, 2018 | 02:33 PM
fastlt1's Avatar
Default Do it all cam
First off this is not for max effort. I know one cam will not make max power in all conditions. But what would be a good cam for a 10.5:1 408 stroker. Good on n/a but can handle 250 to 300 shot and later on be used with turbo. Before people blow up. People have sprayed and boosted the **** out of stock cams. Looking for a cam that will pick up good NA but be versatile.
Old Feb 12, 2018 | 02:53 PM
NAVYBLUE210's Avatar
From: Coast of San Mateo County Between Pacifica & HMB
Heads?
Transmission?
Chassis/Weight?
Application/Goals/Useage?
Old Feb 12, 2018 | 03:22 PM
fastlt1's Avatar
243 heads
3500 weight
Track
99 z28
Auto 3600 stall
Old Feb 12, 2018 | 03:34 PM
HCI2000SS's Avatar
Since you basically want a cam that's decent in all applications you'll probably want a custom grind of some sort. I'd call the vendors on here who specialize in this, since your scenario is not the typical one
Old Feb 12, 2018 | 03:38 PM
JakeFusion's Avatar
Super Hulk Smash
234/239 .612"/.610" 115+5 from John Bewley and sold through BTR would be a good cam. Would be a mild NA cam in the 408 and be decent with an S480 type of turbo down the line that sees a lot of street duty.
