Old Feb 20, 2018 | 08:48 PM
Adrian Leal's Avatar
Default 02 4.8
I have a 02 Silverado with a 4.8 with the xr275 566/568 112lsa with the 08 intake with 92mm TB what I recently done is put the tsp double springs on with tsp pushrods what I wanted to know if those springs are to hard for that cam
Please lmk asap
Thank you
Old Feb 21, 2018 | 07:04 AM
JoeNova's Avatar
Restricted User
Spring pressure doesn't really have any effect on a cam..
Old Feb 21, 2018 | 08:03 AM
epfatboy's Avatar
It will however put more stress on the lifter, of specific concern is the roller wheel/bearing. Just make sure to get the softest seat/compressed spring pressure for your config, typically this is driven by can lift.
Old Feb 21, 2018 | 08:12 AM
What rpm are you looking to spin it to?
Old Feb 21, 2018 | 12:23 PM
Oh ok cause the cam is from 1800-6800 and im pushing it to 6950rpm but whats weird to me before I swapped out the ls6 blue springs it ran 13.8@96.7
And after the springs it ran 14.034@95.2 so idk what's causing that
Old Feb 21, 2018 | 12:34 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
Where does the cam stop making power? Did you shim the springs?
Putting a dual spring kit on those lobes and that lift is more than overkill.
Old Feb 21, 2018 | 12:40 PM
I left the original valve stem seals on it I didnt put the seals that come with the springs but it does fit tight on the originals and roughly when it hits 3rd its just making noise dont really feel it pulling
Old Feb 23, 2018 | 09:16 PM
stockA4's Avatar
put the LS6 springs back in it they will last 100k miles, those duals aren't needed with the gentle lobes on that cam. I have 265 version of the cam you are running in my 4.8 and I drive it everyday and spin it up to 7k without issue.
