L33 piston question
Old Feb 26, 2018 | 07:36 AM
tlavoie87's Avatar
Default L33 piston question
Need to know if a gen 4 piston 19208675 will work with an l33.. the l33 has floating wrist pin and dimpled rods.. also I'm aware the compression would be a little bit lower due to the valve reliefs and was going to shave the heads .030 to make up for it .. any thoughts I am new to the ls world and this is my first build thanks
Old Feb 28, 2018 | 08:01 AM
tlavoie87's Avatar
Anyone?
Old Feb 28, 2018 | 09:40 AM
RonSSNova's Avatar
Should be fine. As long as they are for full floating rods. Which it should being gen IV
Old Feb 28, 2018 | 10:12 AM
tlavoie87's Avatar
thanks ron..yes both full floating
Old Mar 3, 2018 | 04:58 AM
8.Lug's Avatar
The real question is - why?
