Interested in the answer here.
Old Feb 28, 2018 | 10:44 AM
jaxcam02's Avatar
Default Interested in the answer here.
I just finished doing a head and cam swap on my LS1. I tried google searching for the answer but couldnt really find it.
Every single one of my pistons had a tiny little hole machined into them. They were all at the 3 o clock position IIRC.
Is that a balancing hole, or something else?
example of the hole. not from my engine
Old Feb 28, 2018 | 10:46 AM
KCS's Avatar
KCS
Moderator
Those holes are to indicate which way the pistons should be installed. The dots face to the front of the engine.
Old Feb 28, 2018 | 10:47 AM
99 2500's Avatar
The dot is used help for correct installation of the piston, they are all suppose to face the front of the engine.
Old Feb 28, 2018 | 10:50 AM
jaxcam02's Avatar
awesome, thank you. I was just curious.
does it really make that much difference though. Is the rod and crank offset a tiny bit to make a difference?
Old Feb 28, 2018 | 03:48 PM
Yes, piston pins are offset on most, if not all LS engines.
