2006 silverado 5.3l rod bolts
I am replacing all the rod bearings( in frame ) on my truck. THis is the first time it comes apart. Can i reuse the rod bolts. Do i need to add an extra 10 degrees after the new 85 degree spec.
So get new bolts and torque to spec.
Connecting Rod Bolts - First Pass
20 N·m
15 lb ft
Connecting Rod Bolts - Final Pass
85 degrees
Re using tty bolts is a horrible idea, ESPECIALLY on rod bolts, they are never the same after first use. All it takes is one to stretch out at high RPM and let go of a bearing and the motor (including the block usually) is done.
Why in the world would anyone risk their engine over a set of bolts.
I wanna see where it says they are reusable.
Do you change your main cap bolts too?
I've seen people say the bolts are reusable but I haven't found an article from manufacturers (auto or bolts) that confirm it. So I was worried it could be hearsay.
I could be wrong, I have been before. But personally I don't see the point in risking it considering the price of some bolts vs the price of an engine.
In the factory manual, It only states the head bolts and the balancer bolt are torque to Yield Applications and the bolts must be replaced.
If the bolts were TTY, the factory manual would state that the rod bolts and main caps would also need to be replaced at time of service. Like in the Duramax engine. It state's to replace the rod bolts.
My apologies for the misinformation. I would personally still replace them though, they're cheap, and we know what happens when a rod bolt stretches under high rpm.
Tensile strength is what would be my concern. I'm genuinely asking, do you guys think a fresh bolt would have a higher tensile strength than a bolt that's been stretched once or twice before?
