243 heads on lm7
Old Mar 11, 2018 | 06:49 AM
Auzzybear's Avatar
Default 243 heads on lm7
I’m putting 243 heads on a 5.3 lm7 I’ve read that they should be decked .030 is this to much?
Old Mar 11, 2018 | 07:02 AM
98CayenneT/A's Avatar
Milling the heads .030" will put you around 10 : 1 cr.
What you using the motor for?
Old Mar 11, 2018 | 07:05 AM
Auzzybear's Avatar
its going in a 94 Sierra daily driver/pick on imports
Old Mar 12, 2018 | 10:56 PM
jetech's Avatar
Veteran: Air Force
I'm not sure but I think you would have to use a 0.040 head gasket to achieve a 10.0:1 cr using 243 heads milled close to .030". Aftermarket cam? Measure ptv clearance , quench and pushrod length
