lifters necessary?
Old Jul 4, 2004 | 03:03 PM
Cerebrex's Avatar
Default lifters necessary?
Would new lifters be necessary for a 228/228 112lsa cam? They are expensive as hell, and I'm seeing a LOT of poeple that don't upgrade them. Thanks for the help!
Old Jul 4, 2004 | 07:03 PM
jrp's Avatar
jrp
SN95 Director
you mean 228/228 112. and unless you plan to pull thee heads you wont be able to swap lifters. most dont change them just for a cam but if you are gonna do heads then i would since you probably have a high mileage car.
Old Jul 4, 2004 | 07:29 PM
Cerebrex's Avatar
Well i have to pull the heads because I spun a bearing and am probably going to have to take the bottom end to a machine shop. So with that being said, would you recommend it?
Old Jul 4, 2004 | 08:31 PM
jrp's Avatar
jrp
SN95 Director
most definately then.
Old Jul 4, 2004 | 09:23 PM
bigdsz's Avatar
I just got a set of 5.3's from AS. I asked Jay if I should change the lifters since I had 72,000 miles. His comment "absolutely not necessary". I really did want to change them but I guess now I won't.
Old Jul 4, 2004 | 10:17 PM
Cerebrex's Avatar
yeah I have 73k and it's expensive as HELL. Anyone know how many gasket sets I'll need for a complete engine disassemble/reassemble?
Old Jul 4, 2004 | 11:29 PM
PREDATOR-Z's Avatar
First of all what you need is an engine overhaul.
That said you will change all bearings, re-hone, rod bolts and resize, new slug rings etc... Anything else is a shortcut and you'll end up doing it twice.
$199.99 for a set of Comp cam replacement lifters is not expensive as hell, and if you look hard enough, i'm sure you can get some a lot cheaper.
Old Jul 4, 2004 | 11:34 PM
Cerebrex's Avatar
"Expensive as hell" is a relative phrase; and to me, it IS expensive as hell for something that isn't necessary. I am spending a thousand dollars on a cam/accessories combination, getting the bottom end machined, and yes, getting new bearings. With that beind said, I am not made of ******* money. And since it isn't that expensive for YOU, maybe you can buy me some ******* lifters.
Old Jul 4, 2004 | 11:44 PM
PREDATOR-Z's Avatar
I see, well if you quit cursing by Christmas, who knows???
Old Jul 5, 2004 | 12:19 AM
Kenny D's Avatar
Yea if you have to take the heads off anyways screw it. And if your buying heads why not pay a extra 200$ and be safe.
Old Jul 5, 2004 | 01:08 AM
Cerebrex's Avatar
not buying heads... I wish I had that kind of money laying around
Old Jul 5, 2004 | 05:56 AM
jrp's Avatar
jrp
SN95 Director
dude seriously, with all the money your already spending whats another 200 bucks. why rebuild an engine and uses lifters with 70K+ miles on them. 200 bucks for some comp 850 lifters is not alot. and no not all of us are made out of money, i got mine brand new for 179. but hey, its your motor
