Good Dual Valve Springs for TR Reverse Split Cam
Old Mar 25, 2018 | 06:15 PM
mrx8200's Avatar
Default Good Dual Valve Springs for TR Reverse Split Cam
So I've been running Patriot gold dual springs with my Thunder Racing reverse split cam ( 230/224 .569/.563 111lsa) for a while (like since Thunder Racing was still around). I've looked and they don't seem to be on the market anymore. Looking to replace them soon and need something similar. Any good reccomendations?
Old Mar 25, 2018 | 07:18 PM
pantera_efi's Avatar
Default Psi 1511 ml
Hi MRX, your Lobe Lift would work well with a PSI-1511 ML Spring.
Your engine will make MORE HP when this spring is fitted.
Lance
Old Mar 25, 2018 | 08:12 PM
Tang2's Avatar
I have a TR227 and recently installed PSI1511's myself. Great springs! I had Comp 987 doubles installed before and started experiencing high rpm valve float. The 1511's took care of that and some.
Old Mar 26, 2018 | 12:02 AM
mrx8200's Avatar
Thanks for the input guys! I'll check them out
Old Mar 29, 2018 | 03:22 PM
omc8's Avatar
Thunder Racing has been out business for quite a while . How many miles do you have on those Patriot springs , like too know when you remove them what kind of spring pressure they test at .
Old Apr 5, 2018 | 08:21 AM
mrx8200's Avatar
Not sure how many miles on the springs. Did the cam in 2010, but only 3 or 4k miles since then. Car is mostly a garage queen now
