Double check dot to dot..
Old Mar 25, 2018 | 10:54 PM
sean byrd's Avatar
Default Double check dot to dot..
Just threw my cam in-wanted to make sure Ive got it right before I put it back together.
Old Mar 25, 2018 | 11:11 PM
brandon6.0's Avatar
Looks right to me!
Old Mar 25, 2018 | 11:18 PM
HappySalesman's Avatar
Yep! It's honestly kind of hard to screw that up. If you're off a tooth, you'll know it.
Old Mar 26, 2018 | 07:23 AM
RB04Av's Avatar
Looks perfect. You're right on #1 & #6 TDC, at #6 firing. #1 is at the end of the exh stroke and start of int stroke. Which ultimately doesn't too much matter which instance of #1 TDC you're at because you don't have to stab a distributor.
Note also, the crank key is EXACTLY in line w the #1 rod throw (45 aka 1:30). When it points straight up the #1 cyl, it's at #1 TDC. A quick simple double-check.
Old Mar 26, 2018 | 10:04 AM
ddnspider's Avatar
Where's your timing chain dampener? Its already predrilled and the covers off. Put one in.
Old Mar 26, 2018 | 11:42 AM
pantera_efi's Avatar
Default Split Overlap Measurement
Hi Byrd, do as "spider" states., install a chain guide.
I NEVER TRUST "dots".
MY REASON is that I have often found errors with THIS method.
A MORE SIMPLE method is to check lifter travel on the "overlap" cylinder either #1 OR #6, the one with the TWO "proud" lifters.
That distance from the deck should be EQUAL.
Lance
Old Mar 26, 2018 | 12:05 PM
sean byrd's Avatar
is is it supposed to have one from the factory?
Old Mar 26, 2018 | 12:24 PM
ddnspider's Avatar
Some do, some don't. Either way, one should be put in.
Old Mar 26, 2018 | 05:14 PM
sean byrd's Avatar
And of course they dont seem to make the dampeners for the earlier blocks anymore. From what Ive read the later ls2 dampeners have different spacing.
Old Mar 26, 2018 | 05:30 PM
Dragls's Avatar
If you say so...https://www.briantooleyracing.com/ls...-88958607.html
Old Mar 26, 2018 | 05:57 PM
sean byrd's Avatar
Originally Posted by Dragls
ordered. Appreciate it!
Old Mar 26, 2018 | 06:03 PM
ddnspider's Avatar
Yup...RDE is the ONLY place making them other than the trick flow bracket thingy.
Old Mar 26, 2018 | 06:26 PM
sean byrd's Avatar
Yup...RDs the ONLY place making them other than the trick flow bracket thingy.
I saw the RDE on eBay for a couple dollars less than the Tooley but Ive never heard of them.
Old Mar 26, 2018 | 06:37 PM
ddnspider's Avatar
Pretty sure Tooleys IS the RDE.
Old Mar 29, 2018 | 02:48 PM
sean byrd's Avatar
Old Mar 29, 2018 | 06:53 PM
RB04Av's Avatar
The damper really just keeps the chain from whipping around at speed. Not like some other kinds of motors (N* is a good example, as well as some of the Frod ones) where the chain is "guided" in some other direction from where it would want to lie on its own.
The RDE definitely is off center on the stock bolt holes. The stock damper is asymmetric wrt the holes, the RDE is symmetric.
Old Mar 29, 2018 | 07:03 PM
sean byrd's Avatar
Now that I think of it I must have had a stupid moment and put it on backwards. :/
Old Mar 30, 2018 | 09:57 AM
Hi ALL, as we see the OP was helped by the Chain Guide "tech", good work to ALL.
MY QUESTION is WHY the original request, the "dot/dot" DOUBLE CHECK was NEVER addressed ?
THIS thread is great, the subject, to request a SIMPLE way to perform a Dot/Dot verification.
Would there by something I am missing ?
Lance
Old Mar 31, 2018 | 06:50 AM
wph351's Avatar
Lance
Would you mind elaborating further? I'm not familiar with this method and would like to learn. I'm unfamiliar with the terms overlap cylinder and proud lifter. Thanks in advance!
Old Mar 31, 2018 | 09:58 AM
Default P/V Tech at Overlap
Hi 351, I will state another VERY COMMON asked question here at LS-1 Tech as the example.
The Piston/Valve distance question is common : "is it safe" to run this camshaft ?
The cylinders are numbered with the piston position of #1 AND #6 being at TDC BOTH at the SAME TIME.
THUS one cylinder will be FIRING (compression) AND the other cylinder will have the inlet/exhaust valves "off the seat" OVERLAP.
This IS were the P/V distance is of CONCERN !
The Valve Lift is caused by the Camshaft Lobe Lift, an item that can be measured AT THE LIFTER.
The "proud" statement is ABOUT that distance "out" of the lifter bore with EASY MEASUREMENT from the crankcase deck/lifter plunger.
I measure with a Dial Indicator Gauge standing on the block deck with the shaft of the indicator placed at the lifter push rod register.
I believe you question is VERY VALID, thanks.
SO now, how did I do ?
Lance
