Reusing crank pin for a keyed damper/balancer?
Old Apr 3, 2018 | 10:07 AM
tommypenguin's Avatar
Default Reusing crank pin for a keyed damper/balancer?
Hey Guys, my motor rebuild project continues to nickel and dime me as I work my way back to the land of the running. I have a supercharged 01 and have a stock crank damper that has been pinned to the crank.
While inspecting my stock balancer thoroughly today I noticed there is some splitting in the rubber. In lieu of this pulled the trigger on a summit balancer, part sum-c2501.
My question is since I've already have drilled my crank previously for the stock balancer pinning. Can I reuse my existing pin and drilled slot on the crank snout with the new balancer key way slot? I would toss some rtv high temp gasket in there as well.
If that doesn't work, should I pin the new damper on the opposite side? Ideally I don't want to have to tap my crank again but will if I have to. Thanks.
Pic of existing crank slot for reference.
Old Apr 3, 2018 | 01:08 PM
00pooterSS's Avatar
Drill the summit balancer, the round pin and the square key hole may not play well together.
