Tick After Cam Swap
New cam, heads, LS7 lifters, Manton 11/32 push rods. Engine runs well and makes good power. No fluid leaks. New balancer, belts, hoses.
Experiencing a "tick" that is most noticeable under light load at about 1700 rpm on the drivers side. Seems to diminish as motor gets warmer. Can't hear it at idle or at higher rpm (long tubes and Corsa has something to do with this!).
Sounds like a lifter tick but could be a small exhaust leak.
Thoughts that come to mind:
- defective lifter, or something stuck in a lifter,
- rocker bolt has worked loose (they were torqued to 22 ftlb and secured with blue loctite)
- push rod too short (but why just one?) so not enough preload. Pushrods were measured for 0.060" preload.
- exhaust gasket leak one one cylinder. Might explain why it gets better as motor warms up? No obvious evidence of an exhaust leak
Ideas on where to start to resolve this?
Thanks
Bend the end of the brake line to be able to get to the under side of the header flanges, but don't bend it too far and fold it over. If you accidentally fold it over cut it with a pipe cutter and try again.
