Inputs on H/C/I package instead of just heads and intake.
Old Apr 13, 2018 | 01:58 PM
FCar2000TA's Avatar
Veteran: Air Force
Default Inputs on H/C/I package instead of just heads and intake.
Long story short, I don't know the specs of my cam, so I am looking for inputs on where to send my 243 heads and get matched heads, intake, cam, and valvetrain.
Since I am getting a new cam, P2V is no longer an issue, so I can get bigger valves and/or have the heads milled more for higher compression.
So, my main question is larger valves vs more compression... which is better for 1/4 mile times on a daily driven LS1?
Larger valves will likely be TEA stage 2 heads.
More compression will likely be AI 226cc heads, maybe TEA stage 1.
Old Apr 16, 2018 | 10:23 AM
jaxcam02's Avatar
Just do both. I know texas speed can put the larger valves in the 243/799's with a complete CNC valve and port job and can mill to your specs.
Old Apr 16, 2018 | 11:15 AM
FCar2000TA's Avatar
Veteran: Air Force
I was leaning torward AI, and since I am going flex fuel, my tuner recommended going with higher compression. So, I am going to see what high compression heads and cam specs can be done.
Old Apr 16, 2018 | 04:14 PM
Mike Morris's Avatar
Love my AI heads. Good luck with yours
Old Apr 16, 2018 | 10:32 PM
TXZ28LS1's Avatar
Call texas speed...nuff said.
Old Apr 17, 2018 | 12:29 AM
FCar2000TA's Avatar
Veteran: Air Force
Texas speed doesn't port intakes. I want heads and intake ported by the same shop, preferably port matched.
Old Apr 17, 2018 | 10:12 AM
Frankenstein's Avatar
We'd be thrilled to port your intake, heads, and even spec out a cam for you. Give us a call, e-mail, or msg us on Facebook.
Old Apr 18, 2018 | 10:36 AM
FCar2000TA's Avatar
Veteran: Air Force
I am trying to figure out if there is a "sweet spot" between 243s compression and cam. i.e. 10.6:1 and a 230ish cam vs 11.1:1 and a 220ish cam.
