5.3 240sx Build
Something like 222/228 would be my suggestion.
But...
My best advice... contact Stephen @ Cam Motion for a custom
Grind for an extra $50 get something perfect for your combo
(Cubes, Heads, Gears, Weight and application) his screen name
On here is Speedtigger, super smart & friendly, he has helped a lot
Of guys here.
Good Luck
I supply an Avon Gear timing set, the strongest and the ONLY one with "pin" Oiling Holes. The Sprockets are Steel and heat treated.
I can supply a 2010 GM Camaro OEM Oil Pump shimmed for pressure increase.
I would fit King Bearings.
Do you have an AL GEN-IV Block ?
Lance
