Nitrous cam
That cam you have should still be ok with a 250 shot. Once you go over the 250 shot I'd start trying to optimize the cam and heads (nitrous exhaust port for example).
Depends on you goals. I'd see how the current shot with the new heads does first (one change at a time). I think the Stage 3 and 4 are good to about a 200 shot. A nitrous cam would be best but probably loose some low end N/A.
