pan vacuum
Old May 4, 2018 | 11:29 AM
rgw's Avatar
rgw
Default pan vacuum
I have a new rebuild ls1 main/rod clearance 0.002 bore is 99mm new milling oil pump cam .550/.550and I discovered that I have enough vacuum in the pan that running it will collapse a oil container I have 3 more ls cars with no pan vacuum any idea what's wrong?
Old May 4, 2018 | 01:06 PM
Check your PCV system. It's not ventilating.
Old May 4, 2018 | 02:30 PM
00pooterSS's Avatar
Sounds like it's sucking through the PCV but the fresh air side is blocked.
What's your pcv setup like.
