Backfire at idle and performance issues after cam install
Over the winter i swapped somethings on my 99 Trans Am i swapped the cam to a 218/227 .600/.600 112+2 LSA, i replaced the lifters with ls7 lifters and i put on a BBK SSI intake manifold. The car was previously Bolt Ons only and had a mail order tune. Once i put everything back together it started right up idle jumped around a bit until it learned the cam. I thought everything went well until the car started backfiring/afterfire out of the exhaust. it does it about every 10-20 sec and varies in sound from a little pop to a gunshot. As expected the car runs like crap and has a pretty big loss in power. Given the cam specs i thought it could of just needed to be tuned. So i got a tune from a well known tuner via email and the car still backfires and runs poorly. I'm 99% sure i didn't mess up the timing Cyl's #1,6 were TDC and i aligned the timing gears dot to dot. The cars manifold pressure reads 49-50 kpa at idle so i don't think its vacuum related. The spark plugs have about 5,000 miles on them and seemed in good shape when i put them back in. Today i found one of the plug wires was broken and wasn't locking onto the spark plug and i could pull the wire off with little resistance, So i replaced the wires and still no change. The car isn't throwing any codes either. I'm starting to run out of ideas here.
