4.8 crank question
Old May 14, 2018 | 12:14 PM
JoeNova's Avatar
Restricted User
You're making it complicated.
Use a forged 5.3 piston setup for a typical 6.125" rod. The compression height is different to offset the .027" longer rod.
Therefore you'll want roughly a .027" longer rod on the 4.8, making a 6.300" rod your only option.
No custom parts. No issues.
Old May 18, 2018 | 04:37 PM
nickpohlaandp's Avatar
You are correct, I was making it complicated. Thanks for the clarification. That makes perfect sense!
