Pushrod Length - PRC 225 Head
Currently set up with:
LS1
PRC 225 as cast heads-62cc combustion chambers
Cometic .40 Head Gasket
Morel 5315 lifters
Torquer V2 cam
Stock Rockers + Straub Bushings
Tried this on the #1 cylinder intake and exhaust valves with identical results.
With the comp checker threaded out 12.25 turns, and rocker snugged down....I still have play at the rocker tip. Threading the checker out an additional 1/4 turn (12.5 total) all play goes away. This would be zero lash correct? Or is more accuracy than .25 of turn required (such as 1/8 turn)? Probably a stupid question, just trying to get it right.
With that....I get the following length before accounting for preload:
(12.5)(.050)+6.8=7.425
I see a wide range of preloads being shouted for these lifters, but .045-.050 appears to be acceptable with an aluminum block/head.
That gives me 7.475" with .05" of preload.
Am I on the right track? Thanks.
LS1
Morel 5315 lifters
Torquer V2 cam
