Smoking parked on incline
Old May 19, 2018 | 07:31 AM
fastlt1's Avatar
Default Smoking parked on incline
I've searched and can't find any thing. My 2005 2500hd 6.0. If I parked it on a hill nose up it smokes when start. No smoke on level or nose down hill. If sitting on level with race car and trailer hooked to it. It smokes on start up because nose in air. If I watch how I park it doesn't consume any oil. But if I don't it will between oil changes. Any ideas.
Old May 19, 2018 | 07:53 AM
Old Geezer's Avatar
Valve seals on rear cylinders?
Plugged drain back, flooding the rear cyl valves?
Old May 19, 2018 | 10:18 AM
RockinWs6's Avatar
Might only be plugged on one side too, I seen that a few times.
Old May 19, 2018 | 10:42 AM
fastlt1's Avatar
Could a person just pull valve covers and clean top off heads good. And change oil. Maybe wash out with diesel or something
Old May 19, 2018 | 11:19 AM
RockinWs6's Avatar
I'd pull both covers and get a look at them, see if either side looks blocked with sludge. Would have to be something blocking the rear oil return in the head. I've seen debris block return holes too like broken valve seals or believe it or nor pieces of paper or oil bottle seals. People actually drop crap into their engines without knowing or accident and if it can't get past the oil return that's where it stays. I seen pieces of paper towels too.
Might want to park it on a incline like you mentioned then pull the covers, should tell all.
Old May 20, 2018 | 07:25 AM
lizeec's Avatar
Is it smoking from the exhaust pipe or just smoking from under the hood, possible bad valve cover gaskets and leaking out and dripping on to the exhaust manifold, as oil will puddle in the back of the head on an incline, causing it to leak out if you have faulty valve cover gaskets.
Old May 20, 2018 | 08:15 AM
fastlt1's Avatar
Sorry should have said exhaust pipe
Old May 30, 2018 | 04:29 AM
8.Lug's Avatar
It's probably oil pooled up inside your intake.
Old May 30, 2018 | 10:19 PM
RockinWs6's Avatar
Very possible.
