btr stage 2 cam pushrods and springs
Old Jun 6, 2018 | 12:42 PM
fst100's Avatar
Originally Posted by Mavn
Ill continue to run my Horse **** cam and make 580 rwhp with a measly ls3. lol
that's quotable gold!
Old Jun 6, 2018 | 12:50 PM
Mavn's Avatar
"I MAID THEESE"
HAHA
Old Jun 6, 2018 | 01:46 PM
Bspeck82's Avatar
damn, so my previous lq4 on stock compression with a 232/238 cam doing low 12s with 115mph trap speeds at 500-800' above sea level with 3.73s on a baby 3200 stall and was able to drive around without stalling too big?
*lol I'm adding fuel to the flame
yup I'm saying just that. More to it than you think. Now the lq4 is a 6.0 correct? It can swallow a bit more duration given it has more displacement. What were the centerlines? Duration at .050 doesn't tell me much at all. That cam in that motor making all that noise and running 12s isn't to brag about imo. It isn't stock compression that's impossible because the bigger cam robs cyl pressure at lower rpms by it's very nature. Dynamic compression ratio is what mostly matters. That cam isn't big enough to cause problems on the street but it sure could have been way better. Not knocking your car man but I'm just stating facts. You don't believe me go call an engine builder or even the cam guys and ask them. I guarantee you they would want more static compression to raise dynamic compression and more stall to get you higher in the PB at launch. Gears are fine. You would gain from better heads. Perhaps ported stockers with a good valve job and blend with a little bigger valve so it can breathe more up top. And a fast 102 with the combo mentioned. Then it would be a good "hot street" car. It would probably be a pig in a busy city but that's a tradeoff you decide if you want to make.
Old Jun 6, 2018 | 01:56 PM
Bspeck82's Avatar
Just to be clear since when people are wrong they tend to mince words around. "Overcammed" does not just mean your car will not idle and run like garbage on the streets. Overcammed is a cam too big to make efficient use of the rest of the combo but can include not being able to run civilly on the street. If you have stock gears (3.23) and run a cam with 23x 23x duration and tight centerlines that makes power at 4krpm and up but you have a 3200 stall, you have overcammed. If you have a cam that wants to run out to 7k rpm but is bottlenecked because of an ls6 intake or stock heads, you have overcammed. Can't cruise in 6th? Overcammed. Not enough vacuum to run the basic power brakes and steering? Overcammed. .620 lift on a head that flows only up to .550? Overcammed.
and what will you gain from this? A tenth of two? You would be amazed how good a mid 22x cam with wide centerlines will run with some good afr heads or other quality aftermarket heads. Low 11s high 10s and still be comfortable and not make a ton of noise.
Old Jun 6, 2018 | 02:10 PM
stockA4's Avatar
Still don't know what length pushrods he needs
Old Jun 6, 2018 | 02:22 PM
Bspeck82's Avatar
only way to know use a tool to check. Comp sells one. Or make an educated guess.
Old Jun 6, 2018 | 02:27 PM
ddnspider's Avatar
x1000.
Old Jun 6, 2018 | 05:35 PM
02ls1camaroz28's Avatar
My 7.4 pushrod length is perfect, I also was incorrect the cam is a 112 lsa and Texas speed said with my 3800-4000 stall and 3.73 gears it should be perfect. Oh well we shall see
Old Jun 6, 2018 | 05:56 PM
Bspeck82's Avatar
what are your plans with the intake and heads?
Old Jun 6, 2018 | 06:30 PM
I’m going to run the ls6 for now with 241s and this winter throw a set of prcs and maybe a fast 102 intake depending on how the car runs.
Old Jun 6, 2018 | 07:23 PM
Bspeck82's Avatar
well if it was me I would see if they will let you swap the cam to a 224/224 112+0 .600 .600. This will give you an ivc of 44 evo 44 which will peak around 6100 (ls6 style intake peaks around 6400 max due to runner design) and make tons of torque. It has 0° overlap at .050 so it should idle smoothly and make decent power up top. Peak torque should be around 4800ish rpms. Use a decent head like an afr 220 (if you got the cash) or get some ported 243/799s with a good valve job. You will be in the low 11s and be able to drive it as a daily. Best of both worlds. Want to go faster? Nitrous. Doesn't take much and isn't that expensive. With your stall and gear it will drive great and be a beast on the street. You won't need an insane amount of static compression to get the dynamic compression up either. It would be a great 91 pump street car.
Old Jun 6, 2018 | 08:31 PM
  #32
Bspeck82's Avatar
http://www.iskycams.com/tech-tips-2000.html#2003
worth a read. This guy knows his stuff.
Old Jun 8, 2018 | 09:11 AM
  #33
Tbh I like my cam choice I had Texas speed spec it out. I figure they know what works and what’s the best combination since they are real cam experts.
Old Jan 11, 2021 | 02:07 PM
  #34
Jimbo1367's Avatar
I Daily drive a 251/259 .660 lift cam lol if its tuned right itll drive fine..
Mann,
but you’re a animal. LOL
