Timing chain tensioner bolts
Old Jan 5, 2021 | 04:47 PM
Collin King's Avatar
Exclamation Timing chain tensioner bolts
Hi, does anyone know the bolt size for the timing chain tensioner on a gen 3 engine? Thanks.
Old Jan 6, 2021 | 12:41 AM
dixiebandit69's Avatar
8mm X 1.25mm.
I don't know the exact length, but I'd estimate 150- 200mm.
Old Jan 6, 2021 | 05:28 PM
00pooterSS's Avatar
There is no tensionser on a gen 3
But a lot of bolts on an LS are 8x1.25 thread
However, if you're running an aftermarket chain damper then I don't know what they use. And if you're using the bracket style those use different bolts, the cam plate bolts and the damper to bracket bolts.
So which bolts are you asking about lol
Old Jan 6, 2021 | 07:28 PM
ddnspider's Avatar
My ls6 block came with the dampener hole threads...
Old Jan 6, 2021 | 08:31 PM
Sacrilege's Avatar
My ls6 block came with the tensioner hole threads...
Damper, not tensioner. And as far as I know, all aluminum blocks are predrilled, iron blocks are not.
Old Jan 7, 2021 | 06:14 AM
ddnspider's Avatar
Yes dampener.
Old Jan 10, 2021 | 12:58 AM
To clarify, I have this engine here Chevrolet Performance 19370163 Chevrolet Performance 6.0L 364 C.I.D. 452 HP Long Block Crate Engines | Summit Racing. The chain I installed had quite a bit of slack in it so I bought this style
Amazon.com: ACDelco 12630107 GM Original Equipment Timing Chain Tensioner Kit with Bolt and Gasket: Automotive Amazon.com: ACDelco 12630107 GM Original Equipment Timing Chain Tensioner Kit with Bolt and Gasket: Automotive
. The engine came with the bolt holes for it already so I ended up using 2 of the cam sprocket bolts and it works well.
Old Jan 11, 2021 | 07:13 PM
patSS/00's Avatar
Originally Posted by Collin King
To clarify, I have this engine here Chevrolet Performance 19370163 Chevrolet Performance 6.0L 364 C.I.D. 452 HP Long Block Crate Engines | Summit Racing. The chain I installed had quite a bit of slack in it so I bought this style Amazon.com: ACDelco 12630107 GM Original Equipment Timing Chain Tensioner Kit with Bolt and Gasket: Automotive. The engine came with the bolt holes for it already so I ended up using 2 of the cam sprocket bolts and it works well.
I wonder if that would bolt to the Trick Flow dampener bracket for blocks that aren't pre-drilled (which is lots of AL blocks, like mine). Also wondering what you do with that paper clip thing on the end.
Old Jan 11, 2021 | 09:06 PM
The paper clip thing on the end is actually a pin. So once you get the tensioner installed and the timing chain then you pull the pin because the pin keeps the spring up for installation. The spring adjusts from there to keep the chain tight all the time.
Old Jan 12, 2021 | 05:13 PM
00pooterSS's Avatar
I call it the grenade pin. Cause once you pull it you better hope the timing is right. Lol but that's with hydraulic tensioners that are a pain to deal with once the pin is pulled, not so much with this setup.
