[VR] Awakening a 4th Gen Z/28
Old May 24, 2018 | 04:20 PM
David@Vengeance's Avatar
Default [VR] Awakening a 4th Gen Z/28
This 28k original mile Camaro Z28 arrived to us from a local customer who was given the car from his father who had passed recently. The goal for the car was to put together a package to make the car perform and sound like he always wanted it to be, while putting drivability and reliability before anything else. For this, we comprised the following build package to help reach his goals and give even more enjoyment from the vehicle. This car will be hitting the local streets as well as some of the upcoming ½ and ¼ mile racing events throughout the season, so stay tuned for performance results coming soon!
SLP Air Lid *previously installed by customer*
SLP Longtube Headers *previously installed by customer*
SLP Loudmouth II Exhaust *previously installed by customer*
FAST 92mm ported intake manifold Nick Williams 92mm cable throttle body Vengeance Racing
36lb/hr fuel injectors
Walbro 255lph fuel pump
Trickflow As Cast 220cc cylinder heads
Vengeance Racing VRX5 camshaft kit
FTI 3200 11” torque converter
RPM Transmissions level 6 4L60E transmission
10-bolt rear end with 3.42 gear
OEM aluminum driveshaft
UMI C5 front brake conversion
EBC rotors and Hawk HPS brake pads
BMR lowering springs
BMR adjustable panhard bar
BMR lower control arm relocation brackets
Koni SRT.T shock kit
BMR hollow front and rear sway bars
OEM replica 17x11/17x9.5 chrome ZR1 wheels and Nitto NT555 G2 tires
Old May 24, 2018 | 07:01 PM
Bspeck82's Avatar
Very cool. Interested to see track numbers. It begs for a 9" 3.70 gear steel DS and a 9.5" 3600 stall and a 28" tire.
Old May 24, 2018 | 07:04 PM
HCI2000SS's Avatar
I have a feeling the track numbers will be more impressive than the dyno numbers
Old May 24, 2018 | 08:49 PM
Bspeck82's Avatar
Definently Will need more gear and stall with that cam though. It will be a dog down low.
Old May 24, 2018 | 08:53 PM
I have a feeling this was built to be a highway runner/corner carver. Though the rear suspension arm relocation brackets will compromise handling to a degree. They are more of a drag racing mod.
But you may be right, with that cam some deeper gears might be needed even just to cruise.
Old May 25, 2018 | 12:31 AM
Bspeck82's Avatar
Im sure they have their reasons. What I would do does not matter.
Old May 25, 2018 | 09:33 AM
Mavn's Avatar
"I MAID THEESE"
Low *** dyno numbers for that setup
Old May 25, 2018 | 10:15 AM
Ls7colorado's Avatar
very nice! love that video
Old Jun 18, 2018 | 10:14 AM
99Silver6.0's Avatar
Which converter was it that was used for this setup? The StreetBrawler?
Old Jun 19, 2018 | 09:49 AM
Yes sir!
Old Jun 19, 2018 | 10:11 AM
SRT8.Acelleration's Avatar
408/360 ..... Something is not matched properly.
Old Jun 20, 2018 | 04:33 PM
The car actually works great on the street. It's not the biggest camshaft, As Cast cylinder heads, 11" torque converter, and a SLP header/exhaust combo that the customer had on previously. It's definitely not a record setting combination but something that worked for the customer's goals and budget.
