just got these heads and the coolant crossover pipe bolt is tapped into the water jacket. Im not sure what to do. Id like to not mess with sending back and forth and be able to run with a sealant. But what do you all think should be done. Pics attached
I have the coolant crossover pipes and plugs for ls6 intake. Btw this is on a 2000 trans am. And I dont want to put vendor out there unless beneficial to my solution. As I know things happen and they have been great to me for everything else. Im worried about the actual bolts leaking coolant around them as the hole is bigger than the picture show as the metal is able to be picked right off. Its just barely hanging in there. Almost a full tap into the jacket. Wasnt sure if sealant would work or thread dope or what to do. Debating on having machineshop tig it up for me. Its a pricey piece to be doing this. Just wondering if you all thought sealant would hold in a cylinder head water jacket
FYI...I just looked at some 241's and a set of 243's I have and they both have a hole through it so don't worry it's supposed to have it. Use the sealant for peace of mind!
Okay thanks. Ive never had the heads off these ls motors and I for sure thought it looked like a hole tapped to far! Now I feel like a dumby. Thanks everyone for the help and effort for piece of mind. Also guess I can share its gonna be tick SNS 3 cam with prc heads but with btr springs & titanium retainers and hollow stem intake. 42 # injectors and ls6 intake
6504 morels. And I looked at both heads and only the one has the bolt hole drilled through so I dont think it was supposed to be like that but I think with some thread compound it wont matter. I have a lifter tick and found some roller bearings from lifter wheel on drain plug which is a good excuse for all of these goodies lol. Hoping lifter coming apart is the cause of the ticking and not the aftermath of a lifter eating itself up and ruining something else. Fingers crossed that lifter bores are good and all is well. Probably going to order a cam retainer today but may hold off until I get a look at the current one. But seems everyone says to run these heads as is. Just debating on what kind of sealant to use.
also on a side note. Anyway to repair a cracked ls6 intake? Its cracked on top of one of the runners. I have another one and would just about give it away if someone wanted it if it was repairable
also check your rocker arm trunion bearings ,for any slop or missing needle bearings.if you have some similar material like the intake ,you could use a soldering gun and melt some plastic on the cracked section of the intake .or try a good name brand of super glue .
How much would it cost to have a tiny little weld put there? If it doesn't cost much I'd do that. If not some RTV silicone should do it, I would put it up through the bottom of the hole, a little on the bolt threads, and a little dab on the bottom of the crossover tube block.
Talked to Texas speed and they said it would be alright to run it. Looking at my 853 heads the bolt is tapped clear threw so I dont see an issue arising.
Had to fish this lifter out of cam hole. Wouldnt come up through the bore. Bores all looked good and inspecting the old cam the lobes look fine. Went with a bigger cam this time which is why I just went with the aftermarkets for better ptv clearance. Also what is a good preload on 6504 morels. Been told a couple things. I think they recommend .030 to .050 but Jw what people run it at. Lucky for me the old cam only has about 20,000 on it. Block is still clean. Putting new cam in today. Lifters are in oil in the sun. That condenser is a pita to get out of the way for me for some reason
Ive come up with 13 turns and some 12 5/8 & 12 3/4 turns. This comes up to about a 7.500 pushrods. Is this okay on the morels? Been told by tick that they set the morels to all around .060 preload. So Im in or around that range since the 7.475s would put me light on the preload on a few of the short ones.
