lq9 with 243 head question
Old Jun 6, 2018 | 05:45 PM
ecoman35's Avatar
Default lq9 with 243 head question
I have a LQ9 in my 72 chevelle with the stock 317 heads truck intake 1 3/4 long tube headers and a 222/226 586/569 114+2 MSD cam. would a set of 243 heads that are ported and polished work well with this combo? Has a 2004R trans. with a 2800 stal and 4:10 gears. Right now doing 370 hp 385 ft on the dyno. any thoughts are appreciated.
Thanks,
Scott
Old Jun 6, 2018 | 05:49 PM
HCI2000SS's Avatar
The 243's are a good choice. I run PRC stage 2.5 5.3 heads on my LQ9, and for their cost I'm happy with them
Old Jun 6, 2018 | 05:52 PM
00pooterSS's Avatar
Thanks,
Scott
Yes they would, and you would be right around 11:1 compression.
Old Jun 6, 2018 | 09:38 PM
Bspeck82's Avatar
Yes. DCR should right at 8.5. Perfect for pump gas and you should make a ton of torque. I'd ask Frankenstein or TEA about what they would recommend you do to the heads. How often will this see the track?
Old Jun 7, 2018 | 05:27 AM
ecoman35's Avatar
very seldom mostly fun weekend car. will need to get it retuned after.
Old Jun 7, 2018 | 09:30 AM
wannafbody's Avatar
TSP Stage 1 243 work great on the street
Old Jun 7, 2018 | 12:47 PM
00pooterSS's Avatar
Make sure and check if they have been milled and if they have see how much so you can see where you'll land compression wise.
Old Jun 7, 2018 | 05:29 PM
ecoman35's Avatar
They have been cleaned up and just milled 3 thousandths to make sure they are flat,
will i be able to drive it to the tuner after changing heads?
Old Jun 7, 2018 | 05:57 PM
00pooterSS's Avatar
With light throttle and high octane fuel you should be okay.
