what headers to use if i do LS6 transplant
Old Jan 6, 2003 | 08:54 PM
thedave8's Avatar
Default what headers to use if i do LS6 transplant
will ls1 headers/manifolds work after swap, do these engines use the same injectors? Should i get lingenfelters al. intake or ls6? due to egr/ crank vents. whats this i hear about dif pcv system and no egr on ls6, aside from vette oil pan should go right in, ideas ?
Old Jan 6, 2003 | 08:56 PM
BIGBOS's Avatar
Default Re: what headers to use if i do LS6 transplant
I think the LS1 manifolds will work, not 100% sure on that though, might as well do headers while you are swapping motors, shorties/midlengths/longtubes...
Whatever you want...
Old Jan 6, 2003 | 09:00 PM
thedave8's Avatar
i'll def. get headers, just not sure what, i know my ls6 exhaust ports are "D" shaped, not sqare ...hope its not a prob. anyone with exp. with these?
Old Jan 6, 2003 | 11:46 PM
taqwache's Avatar
you will not have a problem bolting up any headers to your ls6 heads. they both use the same header. just dont try to use the vette manifods because they are routed different and will probably not clear.
Old Jan 7, 2003 | 01:39 AM
DanZ28's Avatar
There is no EGR on the LS6 nor is there one on 01-02 F-bod's. The PCV is completely different as well, it's better on the LS6...
Dan
