Race Car PCV setups
If so how do you find it?
Also has anyone here blocked off the stock PCV port and vented each valvecover to atmosphere? (With through filters on the valvecovers or T-ing the lines together to a single filter?
Any noticable power issues or ring flutter as a result?
I am more curious than anything
Could I just get rid of PCV all together ad run duel breathers,I have stepped breathers that wont leak because there high enough out of the valve cover just waiting to go back on my car.
Chris
Kyle
I'm having my engine done @ ARE presently. It's gonna be pretty much the same setup as Chris, except a slightly more aggressive cam, and an LSX-90 instead of LS6... also going Z06-85mm MAF. Headers are same specs, but Kooks... yet, I'm putting a TNT-DP kit w/ independant fuel-system on it... we're gonna be jetting it @ +300hp... I've been really woundering about the PCV issues and have no clue what should be done in my situation to avoid issues... I was thinking about getting the track PCV setup + catch-can... but will that be enough ?
HELP...
