Fuel, spark and no start
Back story:
Keeping a long story short: I swapped an LS1 into my E30 BMW, the engine is rebuilt and has never run before. First go around I go to crank it and it doesn't fire at all. Pulled the plugs on #1 and 2 and they've got good spark, and I can see fuel misting out of the exhaust ports as it cranks (manifolds aren't on). The only thing I can think of is ignition and/or injector pulse timing, but I'm really unfamiliar with these engines so any help is appreciated greatly appreciated.
If you've got good fuel and spark... and we'll assume it's good fuel (pressure, clean injectors, correct air/fuel ratio) then the only other thing is compression. Out of curiosity, did you time any of the spark to see if timing is correct?
Was anything changed internally to the motor when you did the swap? or is it a stock (factory parts) ls1?
I would check fuel pressure at the rail, and then do a compression test on all 8 cylinders.
Also, any codes showing up? What MAF are you using?
