AFR 225 Info...
Old Jul 8, 2004 | 07:16 PM
JBsC5's Avatar
Running a 224/224 .563 114lsa cam and wondering whats the best compression ratio to run with the 205's on the street?
I've heard 11.3 to one? is there any downside to running the slightly more expensive dual spring setup other than the few dollars cost on such a mild cam?
Thanks and great writeup..Really nailed the decision for the 205's vs. 225's for me. I don't want a dyno queen on this baby cam setup I have. I want it to run...
Tony your insight is greatly appreciated.
Old Jul 8, 2004 | 08:01 PM
Viper's Avatar
I have the 112LSA cam TR224 now, and wonder the same; will 11:3 to 1 run fine on 94? I want a street torque beast, not worried about dyno numbers. I would go with the dual springs; I run ISKY duals now for this cam. My $.02.
Old Jul 8, 2004 | 08:26 PM
Got Me SOM's Avatar
11:1 is fine and plenty
Old Jul 8, 2004 | 10:20 PM
JZ'sTA's Avatar
11.3 should work just fine with 94 octane and a good tune.
Motor's run more efficent with higher compression and 10.8-11.3 is a good compression to run NA for good horsepower on 93 octane.
LG motorsports almost always takes their H/C motor's to 11.0-11.25:1 CR.
Old Jul 8, 2004 | 10:24 PM
JBsC5's Avatar
Sounds like 11.3 compression is too high for 91 to 93 octane
Thanks guys
JB
Old Jul 8, 2004 | 11:06 PM
Beast96Z's Avatar
Thanks guys
JB
If tuned right, it should be fine.
Old Jul 8, 2004 | 11:31 PM
BLU-BY-U's Avatar
these next few months ought to be very interesting. I can't wait to see some of the results out in the public, both the 205 and 225. I bet we're going to see some awesome numbers, even from the 205s and smallish cams.
I'd like to pull the trigger next spring
Old Jul 9, 2004 | 09:03 AM
PewterZ28's Avatar
Originally Posted by J-Rod
No, I meant that a 205 is just where you need it to be out of the box.
There are a few things that you might do to it, but we are not talking about much grinding at all. Maybe just a bit of cleanup. If you go start hogging out runner, you will end up with a head that is a good paperweight, or something that looks good on a bench but is WAY down on power...
Head porters are often like artists. They have certain "features" to the way they do a port. I think this will become apparent when certain folks learn the lesson the hard way and they apply those "features" to a head and it looks good on the bench and the heads won't make power...
All I will say is that there are lots of places to remove material out of a port. You can remove material out of the wrong places and make a head that looks good on a bench but won't make power. A bench is atool, but no the be all or end all in what works. There are some truly gifted folks out there who understand how air "moves" and how to direct it through a port. Thse are the guys who if they touch your heads can make more power for you...
Then there are the other guys who try real hard and mean well, but... Well, you get the idea.
Now I'm following you. Thanks!
Old Jul 9, 2004 | 09:43 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
Cool..
Don't sweat your static compression. Look at your DCR... Thats going to tell you whethere or not it will ping.
Think about it this way. If you have a small cam with no overalap and X compression, it going to be different than the same compression in a big cam motor with lots of overlap bleeding off cylinder pressure.
Old Jul 9, 2004 | 09:33 PM
JBsC5's Avatar
So after reading this...
The 205 Guy”
If you are looking to build a street/strip car with a camshaft anywhere in the 220's @ .050 or milder, and you want to place the emphasis on STREET (at the cost of some PEAK Hp #'s), the 205 is a better choice. If you are concerned with fuel economy and low speed part throttle "SOTP", the 205 is the right choice. And lets not forget that even with a mild cam that provides a “stealthy” idle, great drivability, and lots of good low and middle RPM performance, you still have the ability to approach 450 HP at the tire. If you want more power and have the money to spend and buy every "bolt-on" in the book, you have the potential to make over 470 HP at the wheel even with the "small" 205's and conservative cam timing. With LOTS of dyno time, my best recorded run has been 481 RWHP SAE corrected
and realizing this fits exactly what I am looking for...with just swapping heads....and keeping all the rest of my existing mods....(having 93 octane readily available)
whats the right compression for the 205 AFR a 224/224 .563 114lsa cam?
Any suggestions on what exactly to order?
Thanks
JB
Old Jul 10, 2004 | 01:20 AM
Tony Mamo @ AFR's Avatar
Flow Wizard
The 205 Guy”
Thanks
JB
JB...
I see you live in the land of 93 octane premium....11 to 1 is a no brainer, and with the higher octane, you won't need the "perfect" tune to stay out of detonation. Mill the heads to around 62 cc's and you will be in great shape.
Tony M.
Old Jul 10, 2004 | 02:52 AM
  #32
Bowtieman4life's Avatar
What kind of gains can I expect with my current set up if I install a set of 205 heads? My cam is a 220/220 .581/.565 w/ a 112 lsa.
Thanks Tony.
Old Jul 10, 2004 | 07:36 AM
  #33
DaddySS's Avatar
Excellent update and thanks.
Sounds like I'm a 205 guy!
Old Jul 10, 2004 | 02:41 PM
  #34
verbs's Avatar
Tony, what would be the after affect of running someone else's CNC program on your bare casting?
Old Jul 10, 2004 | 03:24 PM
  #35
KMStevens's Avatar
what sponsors are going to be carrying these heads, and will the 225's be available by winter of this year?
Old Jul 10, 2004 | 03:27 PM
  #36
Beast96Z's Avatar
I think he said they would be shooting for late august.
Old Jul 10, 2004 | 03:57 PM
  #37
cyphur's Avatar
Old Jul 10, 2004 | 11:35 PM
  #38
HumpinSS's Avatar
A big *** paper weight that flow like mad and makes absolutely no power
Old Jul 11, 2004 | 02:14 PM
  #39
SSC5R's Avatar
WARNING! Bad Seller Alert
what are the 225 heads flowing out off the box right now? I've seen the 205's ,they look sweet. Since Im a turbo 427 car I guess Im going to wait for the 225's. Im still going to bye a set of the 205's for my SS with a stealthy cam and call it good. Thanks for the
Old Jul 12, 2004 | 12:49 PM
  #40
Z06PSI's Avatar
So what sponser/porter has these heads (205's) and are working with them....????
